Should I use alcohol fuel pump rebuild kit with e10 gas? #2554997
09/26/18 12:56 PM
09/26/18 12:56 PM
long time lurker, short time p...
P
PorkyPig Offline OP
PorkyPig  Offline OP
P
There are two fuel pump rebuild kits shown for my Mallory pump, one says for gas the other for alcohol. My gas is e10, so should I use the alcohol kit to be safe? I don't see any options for the regulator kit, just one kit that doesn't say for one fuel or the other.
Re: Should I use alcohol fuel pump rebuild kit with e10 gas? [Re: PorkyPig] #2555002
09/26/18 01:05 PM
09/26/18 01:05 PM
dogdays Offline
dogdays  Offline
And here come the anti-alcohol wackos! Carrie Nation lives!
There is hardly a place in the US where you can buy fuel that DOESN'T contain 10% ethyl alcohol so I'd say use the gasoline kit. However if you are going to use methanol or E85 I'd opt for the alcohol kit.
R.
Re: Should I use alcohol fuel pump rebuild kit with e10 gas? [Re: dogdays] #2555010
09/26/18 01:20 PM
09/26/18 01:20 PM
P
PorkyPig Offline OP
PorkyPig  Offline OP
P
e10, or e15 if that ends up replacing it. I know that's enough ethanol to mess with older fuel systems left sitting around with it. What I don't know is if the fuel being passed through the pump can have an effect on the components too.
Re: Should I use alcohol fuel pump rebuild kit with e10 gas? [Re: dogdays] #2555015
09/26/18 01:29 PM
09/26/18 01:29 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
R.
https://www.pure-gas.org/index.jsp?stateprov=PA
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Should I use alcohol fuel pump rebuild kit with e10 gas? [Re: PorkyPig] #2555539
09/27/18 02:03 PM
09/27/18 02:03 PM
P
PorkyPig Offline OP
PorkyPig  Offline OP
P
Anyone else got a thought on this? If there is no reason not to go with the alcohol kit even if my fuel is mostly gasoline, that's what I plan to get.
Re: Should I use alcohol fuel pump rebuild kit with e10 gas? [Re: PorkyPig] #2555595
09/27/18 04:30 PM
09/27/18 04:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Just get the regular gas kit.. now days with
alky in MOST fuel I wouldnt waste my money on
the alky kit which is make for meth.. you wont
see any difference other than the price
wave
