Re: Left handed threads
[Re: Alaskan_TA]
#2555276
09/26/18 11:02 PM
09/26/18 11:02 PM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
With tie rods, one end is RH & the other is LH so the adjusting sleeves can be turned in one direction or the other to align the front end geometry.
Ring gear bolts on 8 3/4" differentials are also LH.
Thats what i figured, but is there anything else that need to be left handed? And on dana 60’s are they left handed?
[Re: 70charger512]
#2555347
09/27/18 01:25 AM
09/27/18 01:25 AM
Posts: 10,241 Someplace you aren't
SomeCarGuy
I’ve seen your build goals. I wouldn’t bother with the left hand threads unless ARP offers them. Because I wouldn’t do all this and not run a quality stud. Also I’ve not seen a rotor come with those in a swap deal. Even the old school 11.75 factory parts swap used right hand threads.
So unless you plan on knocking out nice new right hand studs to install maybe lower grade left hand studs, it seems to be a nonissue.
I want my fair share
