Indy 360-1 Rockers T&D or HS #255513
03/16/09 10:03 AM
03/16/09 10:03 AM
412 SB Duster Offline OP
I did a search and both where recommended. Which one is a direct bolt on? if any and how did they work out for one's who asked it the past.
The T&Ds have the cup on the adjuster How does it oil the ball & cup at the rocker.if you oil through the shaft and not the push rod?
Heads are on the motor i don't want to disassemble unless i have no other choice. and the blue Indys need to be replaced.
Also are these in stock any where.
Al
Re: Indy 360-1 Rockers T&D or HS [Re: 412 SB Duster] #255514
03/16/09 11:16 AM
03/16/09 11:16 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
did the indys get damaged?
what cam are you running?
Re: Indy 360-1 Rockers T&D or HS [Re: 412 SB Duster] #255515
03/16/09 11:48 AM
03/16/09 11:48 AM
eastern Ky
hilbillyconquest Offline
eastern Ky
i used the t & d rockers. i received them from brian (ou812) on the board.
give him a call he can answer any question you have.
http://www.immengines.com/
they are direct bolt on.
here is a pic...
Re: Indy 360-1 Rockers T&D or HS [Re: 412 SB Duster] #255516
03/16/09 11:57 AM
03/16/09 11:57 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Al, I think T&D are the only manufacturer that makes a bolt-on
single shaft replacement. I believe Jesel only utilizes the rocker
stands with the paired rockers. (T&D make both)
Re: Indy 360-1 Rockers T&D or HS [Re: S/ST 3040] #255517
03/16/09 12:10 PM
03/16/09 12:10 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
i use t&d on my 245 cnc -1 very nice rockers and shafts bolt strait on, best price i found was Bob Mazzolini (rpmazzolini@yahoo.com) hope you cleaned up the heads b4 putting them on.
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Indy 360-1 Rockers T&D or HS [Re: Scamp408] #255518
03/16/09 02:19 PM
03/16/09 02:19 PM
I've had ran the Indy rockers for 4yrs now. When I checked them last weekend they had some gauling on them from the shaft. and the ID of the rockers is messed up it's .004" bigger top to bottom then it is side to side.
The cam is not big 266-274 @ 50 .570 lift
Need new so may as well up grade at the same
time.
AL
How do the T&Ds oil the push rods?
