k frame install? #2554947
09/26/18 11:06 AM
09/26/18 11:06 AM
ny
marcjames Offline OP
ny
can a k frame on 1967 rt be put on crooked does it mount only one way
Re: k frame install? [Re: marcjames] #2554963
09/26/18 11:37 AM
09/26/18 11:37 AM
More info please on what is going on.
Re: k frame install? [Re: marcjames] #2554973
09/26/18 12:02 PM
09/26/18 12:02 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The attaching bolts have a shoulder on them that centers the K as you tighten it down. You are using the correct bolts right? If you are having issues getting everything installed, the K could be bent or there could be old accident damage on the car itself.
Re: k frame install? [Re: marcjames] #2555131
09/26/18 06:22 PM
09/26/18 06:22 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
K frame bolts
Don't be the exception.
Re: k frame install? [Re: burdar] #2555135
09/26/18 06:28 PM
09/26/18 06:28 PM
iagree scope up twocents
Re: k frame install? [Re: Supercuda] #2556203
09/29/18 09:55 AM
09/29/18 09:55 AM
ny
ny
thanks cuda
Re: k frame install? [Re: marcjames] #2556240
09/29/18 12:26 PM
09/29/18 12:26 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Doesn't help to say you need special bolts if they don't show you what they are. You're welcome and I hope that helps.
