What crank pulley do I need?
#2554847
09/26/18 12:44 AM
09/26/18 12:44 AM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
Apparently ATI Super Dapners are a bit thicker than the generic SFI balancer I ran on my wedge. From the ATI website; I appear to have 917122E which uses OE style timing cover, steel case, and "Not an OEM replacement for stock pulley location." I can't seem to find pulley recommendations on their site. Has anyone run into this before?
Re: What crank pulley do I neet?
[Re: gsmopar]
#2554933
09/26/18 10:28 AM
09/26/18 10:28 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Just space the alternator out a lil bit.
[Re: gsmopar]
#2555039
09/26/18 02:30 PM
09/26/18 02:30 PM
Superfreak
Superfreak
How thick is that motor plate?
[Re: gsmopar]
#2555188
09/26/18 08:33 PM
09/26/18 08:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If using a stock style water pump make sure that lines up first.. then you can add spacers/washers to line up the alt.. no reason to make this difficult
[Re: gsmopar]
#2555201
09/26/18 08:55 PM
09/26/18 08:55 PM
MR_P_BODY
So in that case you just need to add a spacer or a few washers to get the alt lined up.. very simple.. you dont even need to spend the big bucks for a trick pulley
[Re: MR_P_BODY]
#2555224
09/26/18 09:43 PM
09/26/18 09:43 PM
gsmopar
Arizona, USA
So in that case you just need to add a spacer or a few washers to get the alt lined up.. very simple.. you dont even need to spend the big bucks for a trick pulley I’m concerned about space if the crank pulley is spaced that far out. Just curious what pulley others are using with this balancer. I’m going with Andyf’s suggestion.
[Re: gsmopar]
#2555642
09/27/18 07:00 PM
09/27/18 07:00 PM
Posts: 360 Ohio
shorthorse
Ohio
[Re: gsmopar]
#2555721
09/27/18 10:09 PM
09/27/18 10:09 PM
MR_P_BODY
So in that case you just need to add a spacer or a few washers to get the alt lined up.. very simple.. you dont even need to spend the big bucks for a trick pulley I’m concerned about space if the crank pulley is spaced that far out. Just curious what pulley others are using with this balancer. I’m going with Andyf’s suggestion. Do you own the crank pulley you show on the engine now.. is so all you would do is move the alt out about 3/16".. I build my own pulleys so it easy for me.. but if you run just the crank and alt you might be able to cut the outer pulley off(but maybe not)
Re: What crank pulley do I need?
[Re: gsmopar]
#2556211
09/29/18 10:32 AM
09/29/18 10:32 AM
Posts: 17,860 S.E. Michigan
ZIPPY
S.E. Michigan
Glad you got it sorted out.
For info purposes I've been using an obscure Moroso pulley on mine. They don't make it anymore so it's better to find something more readily available.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2556214
09/29/18 10:47 AM
09/29/18 10:47 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
For info purposes I've been using an obscure Moroso pulley on mine. They don't make it anymore so it's better to find something more readily available. I've been using the Moroso cast pulleys, myself. You can still find them for sale. They have a solid base, and had mine cut down for proper alignment. Just get shorter Allen bolts.
[Re: sgcuda]
#2556217
09/29/18 11:02 AM
09/29/18 11:02 AM
ZIPPY
S.E. Michigan
For info purposes I've been using an obscure Moroso pulley on mine. They don't make it anymore so it's better to find something more readily available. I've been using the Moroso cast pulleys, myself. You can still find them for sale. They have a solid base, and had mine cut down for proper alignment. Just get shorter Allen bolts. Yeah good point, they do still sell the cast ones. The reference I made was towards the anodized billet one on the left..They still sell that style for brand x but discontinued them for the Mopar applications. I really like that they're solid and can be machined.
Rich H.
Esse Quam Videri
