What crank pulley do I need? #2554847
09/26/18 12:44 AM
09/26/18 12:44 AM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Apparently ATI Super Dapners are a bit thicker than the generic SFI balancer I ran on my wedge.
From the ATI website; I appear to have 917122E which uses OE style timing cover, steel case, and "Not an OEM replacement for stock pulley location." I can't seem to find pulley recommendations on their site. Has anyone run into this before?
Re: What crank pulley do I neet? [Re: gsmopar] #2554848
09/26/18 12:46 AM
09/26/18 12:46 AM
AndyF Offline
AndyF  Offline
Doty makes shorter pulleys. That is what I recommend for my race alternator kits: http://arengineering.com/products/motorplate-kit-powermaster/
Re: What crank pulley do I neet? [Re: AndyF] #2554858
09/26/18 12:57 AM
09/26/18 12:57 AM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
This one (and I'm using your motorplate)?
https://www.dotymi.com/mopar-crankshaft-pulleys/14-crankshaft-pulley-mopar-chevy-.html
Re: What crank pulley do I neet? [Re: gsmopar] #2554933
09/26/18 10:28 AM
09/26/18 10:28 AM
an8sec70cuda Offline
Just space the alternator out a lil bit.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What crank pulley do I neet? [Re: gsmopar] #2555039
09/26/18 02:30 PM
09/26/18 02:30 PM
Superfreak
Superfreak
How thick is that motor plate?
Re: What crank pulley do I neet? [Re: ] #2555124
09/26/18 06:14 PM
09/26/18 06:14 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
1/2 in.
Re: What crank pulley do I neet? [Re: gsmopar] #2555161
09/26/18 07:26 PM
09/26/18 07:26 PM
I have had the ATI hubs shortened on the crankshaft side in the past to align the pulleys work scope
How about using a 426 street hemi crank pulley also first? scope
Re: What crank pulley do I neet? [Re: gsmopar] #2555188
09/26/18 08:33 PM
09/26/18 08:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If using a stock style water pump make sure that
lines up first.. then you can add spacers/washers
to line up the alt.. no reason to make this difficult
wave
Re: What crank pulley do I neet? [Re: gsmopar] #2555197
09/26/18 08:46 PM
09/26/18 08:46 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Running a drop in electric water pump. Thanks for the replies!
Re: What crank pulley do I neet? [Re: gsmopar] #2555201
09/26/18 08:55 PM
09/26/18 08:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
So in that case you just need to add a spacer
or a few washers to get the alt lined up.. very
simple.. you dont even need to spend the big
bucks for a trick pulley
wave
Re: What crank pulley do I neet? [Re: MR_P_BODY] #2555224
09/26/18 09:43 PM
09/26/18 09:43 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
wave
I’m concerned about space if the crank pulley is spaced that far out. Just curious what pulley others are using with this balancer. I’m going with Andyf’s suggestion.
Re: What crank pulley do I neet? [Re: gsmopar] #2555497
09/27/18 12:12 PM
09/27/18 12:12 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I prefer things “tighter” to the engine so I can understand where you’re coming from... the Doty mount on my RB, and small 1 wire alt, I ran his flat pulley on my dampner.
Re: What crank pulley do I neet? [Re: gsmopar] #2555642
09/27/18 07:00 PM
09/27/18 07:00 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
Re: What crank pulley do I neet? [Re: gsmopar] #2555721
09/27/18 10:09 PM
09/27/18 10:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
Do you own the crank pulley you show on the
engine now.. is so all you would do is move the
alt out about 3/16".. I build my own pulleys
so it easy for me.. but if you run just the
crank and alt you might be able to cut the
outer pulley off(but maybe not)
wave
Re: What crank pulley do I need? [Re: gsmopar] #2555744
09/27/18 11:15 PM
09/27/18 11:15 PM
AndyF Offline
AndyF  Offline
Maybe cut down the pulley you have on the engine now? If it is solid you can put it in a lathe and just shave 1/2 inch or whatever you need off the base.
Re: What crank pulley do I need? [Re: gsmopar] #2555797
09/28/18 12:54 AM
09/28/18 12:54 AM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
The current pulley is hollow. It's a March 33% under driven with dual grooves. My DMI bracket has all of the supplied spacers plus a few washers to get the alternator where it is. I no longer need the second groove of this pulley (ditched the P-Steering) and someone (or me) will probably need this for another project. I'm not going to attempt to modify the pulley nor further space out the alternator. I don't mind buying a new pulley. Just wanted to know what others are using with this balancer. Doty pulley ordered yesterday. Thanks!
Re: What crank pulley do I need? [Re: gsmopar] #2556211
09/29/18 10:32 AM
09/29/18 10:32 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Glad you got it sorted out.
For info purposes I've been using an obscure Moroso pulley on mine. They don't make it anymore so it's better to find something more readily available.
Rich H.
Esse Quam Videri
Re: What crank pulley do I need? [Re: ZIPPY] #2556214
09/29/18 10:47 AM
09/29/18 10:47 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I've been using the Moroso cast pulleys, myself. You can still find them for sale. They have a solid base, and had mine cut down for proper alignment. Just get shorter Allen bolts.
Re: What crank pulley do I need? [Re: sgcuda] #2556217
09/29/18 11:02 AM
09/29/18 11:02 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Yeah good point, they do still sell the cast ones. The reference I made was towards the anodized billet one on the left..They still sell that style for brand x but discontinued them for the Mopar applications. I really like that they're solid and can be machined.
Rich H.
Esse Quam Videri
