Valve spring shims don't look good.
#255374
03/15/09 11:50 PM
03/15/09 11:50 PM
Posts: 214 Hershey,PA
mracer360
Hershey,PA
Had a bent push rod and sent the heads out to get checked. The machine shop sent me home with some damaged valve spring shims. Very interesting, wonder how long they would have lasted.
Re: Valve spring shims don't look good.
[Re: dthemi]
#255377
03/16/09 04:15 AM
03/16/09 04:15 AM
Posts: 5,875 communist bloc of new jersey
jamesc
The spring shouldn't sit on the shim. They should go under the cup.
or locator, either way like Darren mentioned the shims are not meant to have the spring run directly on them.
[Re: jamesc]
#255378
03/16/09 08:47 AM
03/16/09 08:47 AM
mracer360
Hershey,PA
Well then, I wonder how they got this way???
[Re: mracer360]
#255380
03/16/09 12:27 PM
03/16/09 12:27 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
The springs rotated on them on witch is common. Thats why you put the softer shims Under the harder locater cups. mike
