possible max wedge sport fury #2553412
09/22/18 11:25 PM
09/22/18 11:25 PM
wi
Furys Offline OP
Furys  Offline OP
wi
bought a sport fury about 6-7 years ago,no motor tranz,roller,not much interior,been working on it making a street rod type ride,in my checking out the numbers on the car I have found out it may be a max wedge car,the fender tag shows a 9 under the motor number,anyway all the numbers match the fender tag,cowel,speaker tray etc,my question is I don want to retore this car if its a max wedge car,whats something like this worth without motor,rear end tranz?
Re: possible max wedge sport fury [Re: Furys] #2553419
09/22/18 11:33 PM
09/22/18 11:33 PM
WV
Little Detroit Offline
WV
is there a battery mounted in the trunk?
Re: possible max wedge sport fury [Re: Furys] #2553426
09/22/18 11:59 PM
09/22/18 11:59 PM
wi
Furys Offline OP
Furys  Offline OP
wi
no battery anywhere front or back,car was pretty stripped
how ever there are a few holes in the pass side of the trunk,we dodnt know what they were for
Re: possible max wedge sport fury [Re: Furys] #2553433
09/23/18 12:15 AM
09/23/18 12:15 AM
wi
Furys Offline OP
Furys  Offline OP
wi
also read that the 63 steel front end max wedge cars had the battery in the front,only 63,s that had the batteries in the back were the lightweights
Re: possible max wedge sport fury [Re: Furys] #2553434
09/23/18 12:20 AM
09/23/18 12:20 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Check the floorpan for the exhaust brackets that are unique to the MW cars..You should have an extra hole in the dash frame for the MW choke cable as well...Brake lines will be rerouted for the MW exhaust manifolds...ETC.. Plenty of ways to quickly verify if the car is the real deal..
Re: possible max wedge sport fury [Re: Furys] #2553437
09/23/18 12:36 AM
09/23/18 12:36 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Can’t you check a VIN list that Darell Davis published of all MW cars built?
Also Chrysler Historical?
Re: possible max wedge sport fury [Re: Furys] #2553453
09/23/18 01:22 AM
09/23/18 01:22 AM
wi
Furys Offline OP
Furys  Offline OP
wi
Ya will do that,new to this stuff,had no idea it may be a max wedge car till a person looked at my fender tag and so the 9 under the motor number
Re: possible max wedge sport fury [Re: Furys] #2553458
09/23/18 01:50 AM
09/23/18 01:50 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I know your last thread got a little derailed, but if the fender tag matches the car - it's a MAX WEDGE Sport Fury
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2539439/fender-tag-decode.html#Post2539439
post some pics of its current condition & I'm sure you'll get some estimates to value and some "PMs"
shouldn't this be in "WIW"?
Re: possible max wedge sport fury [Re: Furys] #2553627
09/23/18 01:57 PM
09/23/18 01:57 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
You really ought to buy the Davis book on Maxies if you even THINK you have one. Documentation is key, and the info in his book is thorough & fascinating in any case.
Re: possible max wedge sport fury [Re: topside] #2553630
09/23/18 02:03 PM
09/23/18 02:03 PM
WV
WV
how many holes in the trunk area and where were they located??
Re: possible max wedge sport fury [Re: Furys] #2553718
09/23/18 05:14 PM
09/23/18 05:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Depends on the build date, battery moved to trunk on all MW cars February 1963.
Re: possible max wedge sport fury [Re: Furys] #2553943
09/24/18 02:26 AM
09/24/18 02:26 AM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Look at the pass front brake line on the firewall, Max wedge where routed in a different spot than standard engines.
Re: possible max wedge sport fury [Re: Furys] #2553966
09/24/18 08:28 AM
09/24/18 08:28 AM
A727Tflite Offline
A727Tflite  Offline
Post a picture of the firewall - especially the area around the driver side.
Re: possible max wedge sport fury [Re: topside] #2553994
09/24/18 10:48 AM
09/24/18 10:48 AM
blewbyu Offline
blewbyu  Offline
I tried to buy one of his books awhile back and they are not available at this time. I did e mail him about a car and he responded quickly the other day about a car I had found. If you e mail him the vin you can find out very quickly if its a real max wedge car. twocents
ddavis8839@aol.com
Re: possible max wedge sport fury [Re: cudaman1969] #2554040
09/24/18 12:32 PM
09/24/18 12:32 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Like this,brake line from master cylinder is also unique.
Re: possible max wedge sport fury [Re: 62maxwgn] #2554047
09/24/18 12:42 PM
09/24/18 12:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
MW with A/C? Gotta be a clone.
On the correct MW firewall the most noticeable differences, besides the cross-firewall brake line, are the relocated voltage regulator, engine wiring harness and the rerouted brake line from the MC. All of these are easily replicated. I believe the one thing that is usually ignored when cloning a MW is the extra parking brake cable guides welded to the underside of the floor pan.
Re: possible max wedge sport fury [Re: John_Kunkel] #2554079
09/24/18 02:00 PM
09/24/18 02:00 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Like this.
Re: possible max wedge sport fury [Re: 62maxwgn] #2554159
09/24/18 05:39 PM
09/24/18 05:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I once saw a pic of what was reputed to be a MW prototype, instead of the cable guides welded to the floor pan they drilled holes in the floor and installed a couple of seat belt eyebolts and routed the cable through them. I did the same thing when I built my MW clone.
Re: possible max wedge sport fury [Re: John_Kunkel] #2554163
09/24/18 05:58 PM
09/24/18 05:58 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
it is not a mystery shruggy
there were pics in his other thread
post the VIN - someone will let you know if the VIN is in DD's book
Re: possible max wedge sport fury [Re: 6bblgt] #2554335
09/25/18 01:59 AM
09/25/18 01:59 AM
A727Tflite Offline
A727Tflite  Offline
What other thread.
