Re: dim dash lights
[Re: btomasko]
#2550587
09/16/18 12:35 PM
09/16/18 12:35 PM
Posts: 141 Missouri
randavis
Missouri
My uneducated guess would be the ground for the light bar or corrosion on the tips of the bulbs.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI. New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: dim dash lights
[Re: btomasko]
#2550588
09/16/18 12:35 PM
09/16/18 12:35 PM
RapidRobert
I'm thinking the rheostat in the dimmer switch (too much voltage drop). I'd start by jumping 12V to the "out" terminal in the DS & if they brighten up then work upstream from right there starting with the switch itself.
Re: dim dash lights
[Re: LTLBEE]
#2550706
09/16/18 06:41 PM
09/16/18 06:41 PM
RapidRobert
Agreed, access that copper strip on the printed circuit that grounds the bulbs & ground it directly & see if they brighten up
