Page 2 of 3 1 2 3
Re: What cam would I have used in the 70's [Re: lostdog] #2548937
09/11/18 07:18 PM
09/11/18 07:18 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
The Hemi cam in the 70s was a .465 225@50, 80s .471 228@50 and ran power breaks no problem.
Have a great day
Iowan
"obsolete is neat"
Re: What cam would I have used in the 70's [Re: lostdog] #2548971
09/11/18 08:34 PM
09/11/18 08:34 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
[/quote]
Yep these are the hipo 346 heads ! I have actually been considering using some of those other components you mention that are available to me [/quote]
Thought so...the markings on the heads have always helped me. It sounds like you're right on track. This is probably too detailed, but if you can find any of the goofy old metal cal custom type plug wire looms, and maybe the T handle valve cover bolts they would look right at home. having looked at alot of working mans/budget hod rods when I was a kid, this is the kind of stuff they usually seemed to have.
Rich H.
Esse Quam Videri
Re: What cam would I have used in the 70's [Re: 6bblgt] #2549007
09/11/18 10:23 PM
09/11/18 10:23 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Originally Posted By 6bblgt
from the '70 Hustle Stuff catalog * RACER BROWN SSH-25
http://www.4secondsflat.com/RB%20Cam%20Specs.htm
iagree
Re: What cam would I have used in the 70's [Re: lostdog] #2549049
09/11/18 11:42 PM
09/11/18 11:42 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
That 509 cam might not had been the best choice for street performance, but it sure sounded like it was! That bad boy gave the motor a sound of its own.
Like a lot of stuff back in the day, the performance level highly depended on the guy doing the tuning. Some guys had the touch, and others pretended they had the touch. It seemed as though the guy with the touch could make any combo work, and the guys without the touch might have ended up with one combo that worked pretty well, so they stuck with it.
If you really want performance, I'm not so sure any of the old cams would stand up against the newer stuff, but if you want to look and sound the part, the old stuff is hard to beat. Gene
Re: What cam would I have used in the 70's [Re: lostdog] #2549068
09/12/18 12:28 AM
09/12/18 12:28 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Originally Posted By lostdog
I were going to "soup up" my B engine back in the 70's what cam would I have used ?
I'm surprised no one said to use a 3/4 race cam smile
Re: What cam would I have used in the 70's [Re: poorboy] #2549075
09/12/18 12:51 AM
09/12/18 12:51 AM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
I agree and that’s true today too. My original plan was to use the Hughes whiplash cam. But I had a thought that I may just keep it old school. 😁
Re: What cam would I have used in the 70's [Re: DAYCLONA] #2549076
09/12/18 12:53 AM
09/12/18 12:53 AM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Hahaha yeah. That’s the first description I was ever given of a performance cam - in a ‘68 camaro 😂
Re: What cam would I have used in the 70's [Re: charge70] #2549080
09/12/18 01:03 AM
09/12/18 01:03 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Originally Posted By charge70
Crane Fireball.
this, and anti-pump-up lifters
Re: What cam would I have used in the 70's [Re: lostdog] #2549196
09/12/18 01:35 PM
09/12/18 01:35 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
laugh2
My first thought was did you want a 3/4 or full race cam. biggrin
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: What cam would I have used in the 70's [Re: DrCharles] #2549202
09/12/18 01:50 PM
09/12/18 01:50 PM
Originally Posted By DrCharles
Originally Posted By Cab_Burge
I sold a friend a Mopar Purple Shaft 284 street hemi grind for a 383 motor going into a 1968 Charger with power brakes, he owned a automotive garage and it was for one of his bigger commercial customers Son car. I help him degree it, it had right at 4.5 inches of vacuum idling at 850 RPM in gear
That's strange... must have been something else wrong since you degreed it for him. Huge vacuum leak maybe? I put that exact same Purple Shaft cam (284/.484) in my basically stock 383 rebuild. It idled with a very minor lope at 13" vacuum at 750 rpm! shruggy
I was told by a local Mopar Purple shaft lover, he is very knowledgeable on Mopar V8 B&RB motors up, that Ma Mopar had change the LSA on that camshaft, RB&B motor street hemi 284, 484 grind back in the mid 1990s or so work shruggy
I bought several other Mopar brand camshaft later before abandoning them all due to the "590" grind not having .590 net lift down I called them, Mopar hot line, about it and I was told they had change vendors and they knew it wasn't .590 net lift now but they had dyno the cam and they weren't worried about the loss of .040 lift shock puke
Re: What cam would I have used in the 70's [Re: lostdog] #2549209
09/12/18 02:12 PM
09/12/18 02:12 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I know they changed the LSA on the hydraulic .509 and made it much more driveable, so other cams very well may have changed too. But the .484 that I bought was waaay back in 1984, so original shruggy
Anyway there aren't many cams (outside of "4/4 race") laugh that idle at 4" of vacuum! whistling
Re: What cam would I have used in the 70's [Re: lostdog] #2549305
09/12/18 06:09 PM
09/12/18 06:09 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the isky 1012b was the '64 s/s wedge race cam; 320 degrees duration, .520 lift, 108lsa, a lot of cam. the 1012b was superseded by the racer brown stx series; stx21, 22, & 23. the ssh25 and 284-.484 are identical for all practical purposes. the real issue may be how much head modifications your willing to do to run a high lift cam. there are 114lsa versions of the 284-.484 and 292-.509. in my opinion, none of the above.
Re: What cam would I have used in the 70's [Re: lewtot184] #2549332
09/12/18 07:29 PM
09/12/18 07:29 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
What about the old Street Hemi grind 280-.484 ?
Re: What cam would I have used in the 70's [Re: lostdog] #2549336
09/12/18 07:43 PM
09/12/18 07:43 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
509, Torquer 383 intake, 3310 holly, 383 with stock 67 heads, Manley pop up .30 pistons, 68 street hemi converter, 4.88 gears in a 70 all steel Duster. 11.67@117 mph. Idled nice at 600 rpm (after carb work) all back in 1979. Tried 750-850 dprs, never made any difference. It had the M/T valve covers and stock dist (one tiny spring) with a MSD 6 and the yellow Accel coil and wires. Hooker fender well headers with 12" extensions. A little 2 gal Moom tank and a Carter electric pump, 3/8 aluminum line. I might have had $500 in the whole car. Forgot to add, snorkel scoop on the steel hood. Makes me wish I had it back.
get the 509 and don't go overboard with the carb, no Russel fittings, no braided line, no wire looms, fiberglass fan, Moroso air cleaner, no shiny stuff.
Re: What cam would I have used in the 70's [Re: lostdog] #2549341
09/12/18 07:48 PM
09/12/18 07:48 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You can't get the old Street Hemi grind cam from MP anymore. I ran one in my 413 when I rebuilt it in 88, it was in my 300 and had zero problems running power brakes or the HVAC controls. The new version is different.
Don't be the exception.
Re: What cam would I have used in the 70's [Re: lostdog] #2549344
09/12/18 07:50 PM
09/12/18 07:50 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I ran the hydraulic purple cam 284-484 with crower anti pump-up lifters.
Re: What cam would I have used in the 70's [Re: lostdog] #2549378
09/12/18 09:46 PM
09/12/18 09:46 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Back then mine where Racer Brown or General Kinetics. Never owned a purple cam.
Re: What cam would I have used in the 70's [Re: lostdog] #2549464
09/13/18 01:14 AM
09/13/18 01:14 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
crower monarch in my 413 in 1969-70 !
Re: What cam would I have used in the 70's [Re: lostdog] #2551069
09/17/18 02:25 PM
09/17/18 02:25 PM
KY
65pacecar Offline
65pacecar  Offline
KY
I thought everyone ran the vaunted 3/4 Race Cam.
Re: What cam would I have used in the 70's [Re: calrobb2000] #2551077
09/17/18 02:39 PM
09/17/18 02:39 PM
SW CO
HemiSportFury Offline
SW CO
Originally Posted By calrobb2000
hi
Used one too in my 383. Later swapped it for a Stage III solid lifer cam. Was also running Stage III heads. Had to modify the intake for that of course.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Page 2 of 3 1 2 3
