Re: Howards cams and lifters
[Re: Cab_Burge]
#2549019
09/11/18 10:50 PM
09/11/18 10:50 PM
Posts: 10,612 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have recently put some 4-10's in the rear so this cam with a 493 and EZ's will make for a fun stick car I will be adding a cage to the car over the winter to make it legal for the times it will run. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: dartman366]
#2549023
09/11/18 10:55 PM
09/11/18 10:55 PM
fourgearsavoy
Rittman Ohio
Gus, when you decide on what cam and lifters you want you can call Howards but when we ordered the parts for Walts car the guy at howards told us to order it thru Competition Products which is next door to Howards and they will have a better price,I believe it has somthing to do with not undercutting their dealers on pricing. I have heard Competition Products is a great vendor so I look forward to dealing with them. I have to get some new pushrods too I used to get the cut to fit kit from Nick so now I need to find a new pushrod supplier. Gus
[Re: fourgearsavoy]
#2549060
09/11/18 11:58 PM
09/11/18 11:58 PM
Posts: 2,905 Pattison Texas
CSK
Pattison Texas
Gus, when you decide on what cam and lifters you want you can call Howards but when we ordered the parts for Walts car the guy at howards told us to order it thru Competition Products which is next door to Howards and they will have a better price,I believe it has somthing to do with not undercutting their dealers on pricing. I have heard Competition Products is a great vendor so I look forward to dealing with them. I have to get some new pushrods too I used to get the cut to fit kit from Nick so now I need to find a new pushrod supplier. Gus They are a great company to deal with, they had my car on the front of their catalog at the beginning of the year.
[Re: Cab_Burge]
#2549185
09/12/18 01:13 PM
09/12/18 01:13 PM
Posts: 11,786 Portage,michigan
B3422W5
Portage,michigan
I have a Howards 260-264 cam in my stock stroke 10.4 compression 360. Works good street and strip
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: DrCharles]
#2549200
09/12/18 01:43 PM
09/12/18 01:43 PM
Thumperdart
State of confusion
Come on Cab, I've been running an Isky solid roller for years with .680-.660 276-281 @ .050 in a baby 470 and it's far from too big or radical and VERY street-able plus easy on the valve-train............. That's reassuring... if I ever get the Dart out of paint jail, I equipped my 451 with a Mini-Express, which after restoring the lobe taper measures out at .652 272@.050! Not sure on that cam but my Isky is the most aggressive STREET profile they made when I bought it.........tame as a kitten and as powerful as a lion when you stab the happy peddle...........
[Re: fourgearsavoy]
#2549390
09/12/18 10:11 PM
09/12/18 10:11 PM
dartman366
Mt. Vernon, Ohio
Gus, when you decide on what cam and lifters you want you can call Howards but when we ordered the parts for Walts car the guy at howards told us to order it thru Competition Products which is next door to Howards and they will have a better price,I believe it has somthing to do with not undercutting their dealers on pricing. I have heard Competition Products is a great vendor so I look forward to dealing with them. I have to get some new pushrods too I used to get the cut to fit kit from Nick so now I need to find a new pushrod supplier. Gus I bought a lot of things thru them when I was building my 512 and they treated me very well and fair prices.
[Re: fourgearsavoy]
#2549505
09/13/18 09:23 AM
09/13/18 09:23 AM
crabman173
crabman173
The best camshaft I have ever run in anything was an Isky roller--slow ramps maybe but it made crazy power for the size and would never quit going upstairs Slow ramp--fast ramp--all the rage and talk but if you decide you want a camshaft that works and you don't give a hoot about knowing cam craft details call Isky--they KNOW what the cam business is all about --Others feel like you must trust the design computer to SELL camshafts--that may be true but to have a sweet running engine you do not have to have the latest computer designed junk--Herb McCandless said it best--" I have never had a dyno pull into the lane beside me" Sooo many things go into a sweet good running engine-- Some of the most soul satisfying engines ever made on earth were built before or during WWII---they did not have FAST ramps or know what a computer was
Captn Cook took off a couple of hundred years ago to watch celestial events half way around the world--after that England could calculate the distance between the planets in our solar system--NO computers needed
[Re: Thumperdart]
#2549731
09/13/18 07:25 PM
09/13/18 07:25 PM
Posts: 2,490 Sydney,Australia
tex013
Sydney,Australia
[/quote] Yes sir, ISKY The LEADERS not followers in the cam industry............. [/quote] Except their website is 5hite Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
