Re: Howards cams and lifters [Re: 65Fury440] #2548931
09/11/18 06:54 PM
09/11/18 06:54 PM
Cab_Burge Online work
Cab_Burge  Online Work
Gus has a clutch peddle to make up for a lack of low end torque or HP due to the cam selection devil whistling
Re: Howards cams and lifters [Re: Cab_Burge] #2549019
09/11/18 10:50 PM
09/11/18 10:50 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
I have recently put some 4-10's in the rear so this cam with a 493 and EZ's will make for a fun stick car devil
I will be adding a cage to the car over the winter to make it legal for the times it will run.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Howards cams and lifters [Re: dartman366] #2549023
09/11/18 10:55 PM
09/11/18 10:55 PM
Rittman Ohio
Rittman Ohio
Originally Posted By dartman366
Gus, when you decide on what cam and lifters you want you can call Howards but when we ordered the parts for Walts car the guy at howards told us to order it thru Competition Products which is next door to Howards and they will have a better price,I believe it has somthing to do with not undercutting their dealers on pricing.
I have heard Competition Products is a great vendor so I look forward to dealing with them. I have to get some new pushrods too I used to get the cut to fit kit from Nick so now I need to find a new pushrod supplier.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Howards cams and lifters [Re: fourgearsavoy] #2549060
09/11/18 11:58 PM
09/11/18 11:58 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Gus beer
They are a great company to deal with, they had my car on the front of their catalog at the beginning of the year.
Re: Howards cams and lifters [Re: Cab_Burge] #2549161
09/12/18 12:03 PM
09/12/18 12:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By Cab_Burge
Originally Posted By 65Fury440
That be a big street cam up bow
Your my kind of street car driver devil whistling hammer
Come on Cab, I've been running an Isky solid roller for years with .680-.660 276-281 @ .050 in a baby 470 and it's far from too big or radical and VERY street-able plus easy on the valve-train............. work biggrin
Re: Howards cams and lifters [Re: Cab_Burge] #2549185
09/12/18 01:13 PM
09/12/18 01:13 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I have a Howards 260-264 cam in my stock stroke 10.4 compression 360.
Works good street and strip
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Howards cams and lifters [Re: Thumperdart] #2549190
09/12/18 01:19 PM
09/12/18 01:19 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
That's reassuring... if I ever get the Dart out of paint jail, I equipped my 451 with a Mini-Express, which after restoring the lobe taper measures out at .652 272@.050!
drive
Re: Howards cams and lifters [Re: DrCharles] #2549200
09/12/18 01:43 PM
09/12/18 01:43 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
drive
Not sure on that cam but my Isky is the most aggressive STREET profile they made when I bought it.........tame as a kitten and as powerful as a lion when you stab the happy peddle........... beer
Re: Howards cams and lifters [Re: Thumperdart] #2549208
09/12/18 02:11 PM
09/12/18 02:11 PM
I bought and installed a Isky RR 602 grind solid roller cam, 260 @.050 both lobes, in one of my old pump gas motors, it was had slowest opening ramps I've ever seen shock shruggy
The newer race cams have a way different opening and closing rate than the older ones, regardless of the brand scope shruggy
Re: Howards cams and lifters [Re: fourgearsavoy] #2549390
09/12/18 10:11 PM
09/12/18 10:11 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Gus beer
I bought a lot of things thru them when I was building my 512 and they treated me very well and fair prices.
Re: Howards cams and lifters [Re: fourgearsavoy] #2549505
09/13/18 09:23 AM
09/13/18 09:23 AM
crabman173
crabman173
The best camshaft I have ever run in anything was an Isky roller--slow ramps maybe but it made crazy power for the size and would never quit going upstairs Slow ramp--fast ramp--all the rage and talk but if you decide you want a camshaft that works and you don't give a hoot about knowing cam craft details call Isky--they KNOW what the cam business is all about --Others feel like you must trust the design computer to SELL camshafts--that may be true but to have a sweet running engine you do not have to have the latest computer designed junk--Herb McCandless said it best--" I have never had a dyno pull into the lane beside me"
Sooo many things go into a sweet good running engine--
Some of the most soul satisfying engines ever made on earth were built before or during WWII---they did not have FAST ramps or know what a computer was
Captn Cook took off a couple of hundred years ago to watch celestial events half way around the world--after that England could calculate the distance between the planets in our solar system--NO computers needed
Re: Howards cams and lifters [Re: ] #2549599
09/13/18 01:36 PM
09/13/18 01:36 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Yes sir, ISKY The LEADERS not followers in the cam industry............. beer work boogie drive
Re: Howards cams and lifters [Re: Thumperdart] #2549731
09/13/18 07:25 PM
09/13/18 07:25 PM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
[/quote]
Yes sir, ISKY The LEADERS not followers in the cam industry............. beer work boogie drive [/quote]
Except their website is 5hite
catfight
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Howards cams and lifters [Re: Cab_Burge] #2551098
09/17/18 03:37 PM
09/17/18 03:37 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
That's the cam I'm thinking about running in my 463 ... if I ever get around to getting the rotating assembly balanced and putting it together biggrin
72 Plymouth Roadrunner 11.08@123.25
