Radiator selection #2548492
09/10/18 06:43 PM
09/10/18 06:43 PM
California
70Drop Offline OP
70Drop  Offline OP
California
I want to get a radiator that cools a little better than what I have now. It's for my Duster with a 440/500, separate trans. cooler, 3,000 cfm fan, Meziere electric pump. The car runs a little hot both driving on the street and waiting in the staging lanes. I'm often at 200-degrees by the time I get to the starting line.
The aluminum radiator I currently have in the car has a 21-inch wide core, 2 inches thick. The width of the radiator opening on the car is about 23 inches (so the current radiator is a bit small for the opening).
I'm wondering what you guys are running? I really don't want to hack up the car by cutting the core support if I don't have to.
Re: Radiator selection [Re: 70Drop] #2548506
09/10/18 07:13 PM
09/10/18 07:13 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I used a wizard with their shroud that had 4 puller fans. Fit, no cutting in my old demon. In traffic, temp hit 190, fans kicked on & pulled temp down to 170. A little pricey, but worth every penny to me.
Re: Radiator selection [Re: 70Drop] #2548525
09/10/18 08:58 PM
09/10/18 08:58 PM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
What temps does it run on the street?
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: Radiator selection [Re: dart440_72] #2548543
09/10/18 10:08 PM
09/10/18 10:08 PM
California
70Drop Offline OP
70Drop  Offline OP
California
[/quote]
[/quote]
Usually about 190-200
Re: Radiator selection [Re: rickraw] #2548547
09/10/18 10:25 PM
09/10/18 10:25 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I narrowed my search down to a Wizard radiator, as well. I felt it was the best value for what you get.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Radiator selection [Re: 70Drop] #2548562
09/10/18 10:56 PM
09/10/18 10:56 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
http://prchotrod.com/
I ordered one from these guys. Core size I wanted, hose size and inlet/outlet positioned where I wanted, trans fluid heat exchanger and proper -6 fittings, mounting tabs.... been ok by me, but I’m just a race only guy.
Re: Radiator selection [Re: 70Drop] #2548628
09/11/18 02:03 AM
09/11/18 02:03 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
90* street driving or hot lapping it gets up to 185*.$200 Afco and a 16 inch multispeed Spal fan.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
