Re: Radiator selection
[Re: 70Drop]
#2548525
09/10/18 08:58 PM
09/10/18 08:58 PM
Posts: 314 Medina, OH
dart440_72
Medina, OH
I want to get a radiator that cools a little better than what I have now. It's for my Duster with a 440/500, separate trans. cooler, 3,000 cfm fan, Meziere electric pump. The car runs a little hot both driving on the street and waiting in the staging lanes. I'm often at 200-degrees by the time I get to the starting line.
The aluminum radiator I currently have in the car has a 21-inch wide core, 2 inches thick. The width of the radiator opening on the car is about 23 inches (so the current radiator is a bit small for the opening).
I'm wondering what you guys are running? I really don't want to hack up the car by cutting the core support if I don't have to. What temps does it run on the street?
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
[Re: rickraw]
#2548547
09/10/18 10:25 PM
09/10/18 10:25 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
I used a wizard with their shroud that had 4 puller fans. Fit, no cutting in my old demon. In traffic, temp hit 190, fans kicked on & pulled temp down to 170. A little pricey, but worth every penny to me. I narrowed my search down to a Wizard radiator, as well. I felt it was the best value for what you get.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: 70Drop]
#2548628
09/11/18 02:03 AM
09/11/18 02:03 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
90* street driving or hot lapping it gets up to 185*.$200 Afco and a 16 inch multispeed Spal fan.
