Single groove crank pulley depths #2547190
09/07/18 01:36 PM
09/07/18 01:36 PM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
Were there several different depths of crank pulleys made? I am looking for something on the shallower side because my harmonic balancer is thicker. Is there an application chart that shows the different depths and diameters?
Re: Single groove crank pulley depths [Re: Cuda340] #2547234
09/07/18 03:26 PM
09/07/18 03:26 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I don't know of an depth charts but the Hemi damper is thicker and takes special pulleys.
Re: Single groove crank pulley depths [Re: Cuda340] #2547328
09/07/18 07:27 PM
09/07/18 07:27 PM
VA
dragon slayer Offline
VA
Yes depending on big block small block, hemi etc... What motor are you talking about? There were thicker BB balancers for trucks and late model 440, but the hub depth was the same, even though external ring was wider. the mount surface is what matters.
Re: Single groove crank pulley depths [Re: Cuda340] #2548388
09/10/18 02:16 PM
09/10/18 02:16 PM
Oly Wash
racerlall Offline
racerlall  Offline
Oly Wash
coll little book on pulley ID
https://www.ebay.com/itm/THE-BRACKETMANS-KNOWLEDGE-OF-CHRYSLER-DODGE-PLYMOUTH-PULLEYS-1959-1978-BOOKLT/223121836213?hash=item33f31908b5:g:aQkAAMXQO21RsR8X
Re: Single groove crank pulley depths [Re: Cuda340] #2548398
09/10/18 02:45 PM
09/10/18 02:45 PM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
The engine is a Hemi with an ATI balancer which is thicker than an original, I need one around 1 3/4" in depth, that is just a rough estimate. The two single groove pulleys at home are around 2 1/4" in depth.
Re: Single groove crank pulley depths [Re: racerlall] #2548399
09/10/18 02:46 PM
09/10/18 02:46 PM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
Thats a pretty cool book!
