Re: Fuel pressure regulators.......
[Re: 68DART360]
#2547949
09/09/18 02:49 PM
09/09/18 02:49 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I use a factory gas tank in my mid 10 sec street car. 1/2"pickup, -8 black nylon braided hose to a Holley return style regulator. -6 line to the carb, and -8 return line that goes into the stock gas filler tube. I run 5.5 pounds of fuel pressure and the pump runs quieter and cooler than it did with my previous dead-head setup.
Pump is an Aeromotive Hot Rod polished unit.
[Re: 68DART360]
#2548093
09/09/18 08:56 PM
09/09/18 08:56 PM
Posts: 16,495 On the run…
BloFish
On the run…
How do you know if you have too much pressure, What are the side effects of too much pressure?
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#2548095
09/09/18 08:59 PM
09/09/18 08:59 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
How do you know if you have too much pressure, What are the side effects of too much pressure? One would be boosters dripping fuel while ideling
[Re: BloFish]
#2548096
09/09/18 09:01 PM
09/09/18 09:01 PM
ProSport
Akron, Ohio
How do you know if you have too much pressure, What are the side effects of too much pressure? It will run rich and maybe stumble if fuel is dripping while driving from too much pressure, worse case scenario it can flood past the needle and seat and possibly cause a fire.
[Re: 68DART360]
#2548100
09/09/18 09:07 PM
09/09/18 09:07 PM
BloFish
On the run…
That may have been my problem yesterday I was running it at 7 1/2 lbs.
[Re: BloFish]
#2548147
09/09/18 10:53 PM
09/09/18 10:53 PM
ProSport
Akron, Ohio
That may have been my problem yesterday I was running it at 7 1/2 lbs. Take it down to 5.5 pounds and see how it goes.
[Re: BloFish]
#2548209
09/10/18 01:29 AM
09/10/18 01:29 AM
Posts: 43,232 Bend,OR USA
Cab_Burge
I always ran my race Holley carbs with 9.5 lbs. with the motor idling with both .090 and .100 needles and seats back in the day Make sure the fuel level is not high with motor warmed up also
[Re: Cab_Burge]
#2548213
09/10/18 01:34 AM
09/10/18 01:34 AM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I always ran my race Holley carbs with 9.5 lbs. with the motor idling with both .090 and .100 needles and seats back in the day Make sure the fuel level is not high with motor warmed up also There is no reason in the World to run a carb engine with fuel pressure that high.
[Re: Blucuda413]
#2548220
09/10/18 01:47 AM
09/10/18 01:47 AM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I ran mine at 9 - 9 1/2 lbs also, I think that's what the Holley instructions said. Worked great for many years!! I'm betting they said 7 1/2 MAX.
[Re: pittsburghracer]
#2548224
09/10/18 01:52 AM
09/10/18 01:52 AM
Cab_Burge
I always ran my race Holley carbs with 9.5 lbs. with the motor idling with both .090 and .100 needles and seats back in the day Make sure the fuel level is not high with motor warmed up also There is no reason in the World to run a carb engine with fuel pressure that high. Why not? I was told by several Mopar backed factory drag racers back then to turn the fuel pressure up a half a pound at a time with the motor running warmed up until the pressure started to lift the needles off of the seat and then back it down 1 pound Not all pressure gauges read exactly the same as all other gauges On my current car with the bigger .130 and .150 stainless steel needles and seats for my E85 fuel carb. and having the pump mounted between the front mounted fuel tank and the regulator mounted on the front of the motor plate I do run it at 5.5 lbs. now with no issues
[Re: Cab_Burge]
#2548290
09/10/18 10:58 AM
09/10/18 10:58 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
-10 feeding a fuel log w/ a pair of Holley 803 regulators and an Aeromotive return regulator to set the head pressure. -8 return.
[Re: 68DART360]
#2548377
09/10/18 01:50 PM
09/10/18 01:50 PM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
Thankfully the Barry Grant regulator still works fine. I'm also a DEAD head,in more ways than one...LOL
