No Start issue
#2547726
09/08/18 10:38 PM
09/08/18 10:38 PM
Posts: 1,141 NH
NHCharger
NH
Went to start the Charger to other day, just a click from the starter. Have tried the following: Checked battery, even swapped it with another car. Removed starter, had it checked, still good. Cleaned all grounds, even added another ground wire from neg. battery cable connector to radiator support. Cleaned battery connections. Swapped in spare ignition switch I had kickin around. Swapped starter relay with other Charger. With key in crank position voltage at starter relay stud that goes to starter is 11.3. Voltage at starter is 10.75. Tried jumping across starter relay from stud where battery cable attaches to the stud below. All the same result, just a click from the starter.
My Dad always told me, when setting goals " avoid disappointment, aim low".
Re: No Start issue
[Re: NHCharger]
#2547728
09/08/18 10:40 PM
09/08/18 10:40 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Engine locked up? Put a socket on the crank and see if it turns over freely.
Starter binding?
Re: No Start issue
[Re: RapidRobert]
#2547740
09/08/18 10:59 PM
09/08/18 10:59 PM
Posts: 1,141 NH
NHCharger
NH
I turned motor over by hand. Forgot to put that in my list.
Re: No Start issue
[Re: poorboy]
#2547872
09/09/18 11:57 AM
09/09/18 11:57 AM
RapidRobert
What I would do now is set a known good battery by the LF wheel & with jumpers run it right to the starter. I would clamp the starter small/large terminals together with one red clamp & the other cable to the starter housing then make the final connection(s) out at the batt & have a helper take hold of the positive clamp on the starter terminals cuz it is close to the starter housing & we dont want it to shift & ground out. this takes everything out of the picture except the starter. EDIT & the motor but we have confirmed that it ain't locked.
Re: No Start issue
[Re: NHCharger]
#2547952
09/09/18 02:56 PM
09/09/18 02:56 PM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
Its a no carnk issue not a no start.Id also say starter if it just clicks.But Ive seen bad batterys do the same.Had my 65 out and started perfect.Left cruise and no crank.Jumped and got home.Battery at almst 13 volts.Turn on headlights and drops to 1 volt.Battery just went.That and check cables.Ive sen them corrode inside and crate a no crank.But would still show good volts on meter.Just remember a meter can tellyou say 12 volts but not you wont have amps.Rocky
Chrysler Firepower
Re: No Start issue
[Re: NHCharger]
#2547993
09/09/18 04:26 PM
09/09/18 04:26 PM
Supercuda
About to go away
About to go away
up yours
missed this?
Re: No Start issue
[Re: Supercuda]
#2547997
09/09/18 04:47 PM
09/09/18 04:47 PM
RapidRobert
I missed that he pulled/checked the starter soooo if the batt is good/charged (& he did change it out) then it has to be (I would think) a voltage drop issue. (& clicking is classic inadequate amperage at the starter) but I got sidetracked cuz I just had a bad starter that just "clicked". It threw me too, I was checking batt/cables all to no avail.
Re: No Start issue
[Re: NHCharger]
#2548142
09/09/18 10:43 PM
09/09/18 10:43 PM
therocks
Niles , Ohio
Starter can test good on floor.But not be good enough to start car.Ive seen it before no load it spins OK.Rocky
Chrysler Firepower
Re: No Start issue
[Re: NHCharger]
#2548145
09/09/18 10:52 PM
09/09/18 10:52 PM
Supercuda
About to go away
About to go away
up yours
In crank mode voltage will drop quite a bit do to the hundreds of amps load the starter puts on the battery. I don't see his measured voltages being out of line, though it would be nice to know the the unloaded battery voltage was to begin with.
Problem really is that most people don't look at this stuff when it's working right so they have no idea what to expect. Leaving them to interpret problems with no basis of comparison.
Re: No Start issue
[Re: dan9]
#2549425
09/12/18 11:20 PM
09/12/18 11:20 PM
Posts: 1,141 NH
NHCharger
NH
Update. Got it started. The positive battery cable was cooked. Even with a heat shield around the cables where they pass by the headers the cable still failed. So a not so funny moment. I change out the cable to a new Y.O. cable- same problem - just a click. So when I double checked all my connections I find that the crimp/connection where the cables tie into the battery terminal were loose and partly pulled out and the crimp was garbage. Pushed the wires back in and crimped it with a set of vice grips and it fired up.
Appreciate all the input and advice.
Re: No Start issue
[Re: NHCharger]
#2549515
09/13/18 09:59 AM
09/13/18 09:59 AM
therocks
Niles , Ohio
One rerason I run at least 1 gauge cables on my 65.Mine have been on decades and still like new.But I dont care if it looks factory.Many do.Rocky
Chrysler Firepower
