Largest Wheel/Tire Combo for AutoX
#2547550
09/08/18 12:08 PM
09/08/18 12:08 PM
Posts: 16,145 Mesa, Arizona
dart4forte
Mesa, Arizona
1971 Duster, will an 18X8 wheel work on the front and what’s the largest wheel/tire combo that will work. Asking for a friend.
Abe Lincoln
Re: Largest Wheel/Tire Combo for AutoX
[Re: dart4forte]
#2547615
09/08/18 02:30 PM
09/08/18 02:30 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
1971 Duster, will an 18X8 wheel work on the front and what’s the largest wheel/tire combo that will work. Asking for a friend. How much work do you want to do? I believe 72bluNblu on FABO has 275's on the front and 295's on the back of his Duster with 18 x 9.5's. If you measure pretty well and roll/cut the fender lip you can fit a big tire back there.
[Re: dart4forte]
#2556555
09/30/18 10:17 AM
09/30/18 10:17 AM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
I have 275-35-18's on 18x9 wheels with +35 offset on my Duster on all 4-corners. In the front, it's necessary to push the front fender brace all the way out and also trim the fender tab in the back of the wheelwell some and replace the bolt with a pan head.
My car also has a B-body rear axle and the Dr Diff Mustang cobra brakes. With stock brakes, chances are you'd want a 5-10mm thick spacer for the front at least.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
