Where to purchase correct drum brake adjustment plugs? #2547502
09/08/18 09:51 AM
09/08/18 09:51 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Anyone know who carries the correct reproduction plugs (plastic) that are used to plug-up the (2) adjustment holes in backing plates on drum brake applications? I'm told the correct ones have the center not filled with material, its scalloped out.
Re: Where to purchase correct drum brake adjustment plugs? [Re: vinnyd76] #2547534
09/08/18 11:37 AM
09/08/18 11:37 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Frank Badalsen
Re: Where to purchase correct drum brake adjustment plugs? [Re: vinnyd76] #2547808
09/09/18 03:38 AM
09/09/18 03:38 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Was still avail thru mopar last i ckd
