Re: domintor air filter
[Re: coronetville]
#2547107
09/07/18 11:12 AM
09/07/18 11:12 AM
Posts: 2,691 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
This guy makes a screened velocity stack. Not exactly what you are asking for but good enough for drag racing. Very low profile.
Tim Cummings 530-919-6115
2011 Drag Pak Challenger
[Re: coronetville]
#2547114
09/07/18 11:25 AM
09/07/18 11:25 AM
Posts: 8,048 Mt Morris Michigan
mopar dave
Mt Morris Michigan
I use a moroso drop base air cleaner with a bubble top lid. Currently using a 3.5" wix filter. Fits under a AAR 6 pack hood on a LD block with a indy 400-3 intake. The drop base is about 2-2.5".
[Re: coronetville]
#2547218
09/07/18 02:44 PM
09/07/18 02:44 PM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
Summir did have their bradn with a K&N type air filter.Comes in different heights.have one om my 65.Been on for years.Lots cheaper than others also.still like to find a old set of the 4 stacks they used to run years ago.Rocky
Chrysler Firepower
[Re: coronetville]
#2547293
09/07/18 06:17 PM
09/07/18 06:17 PM
Posts: 4,213 New York
polyspheric
New York
If it's not big enough WOT isn't doing what you want.
Boffin Emeritus
[Re: coronetville]
#2547455
09/08/18 01:37 AM
09/08/18 01:37 AM
polyspheric
New York
The K&N website has a formula to calculate the smallest filter area based on engine size. E.g., a 500" engine @ 100% VE & 7,000 RPM needs a 14" filter almost 5" tall. If the entry shape at the air-horn is good, the filter material need not be centered on the carburetor, but offset, or even connected by a duct.
Boffin Emeritus
[Re: coronetville]
#2547968
09/09/18 03:20 PM
09/09/18 03:20 PM
polyspheric
New York
Ideally, the volume above the air-horn is a giant box in which air is nearly motionless. This allows each throttle disc to have an equal share of intake air (otherwise this is affected by proximity of the intake duct, the can's wall, etc.). The filter occupies some area between the intake duct and the interior volume. The intake duct can be much smaller than the interior volume's cross-section area (and smallest with very high MPH), and is exposed to high pressure cold(er) ambient air. The large area change converts the incoming air speed into pressure. For engines with front distributors, the space behind the carburetor can be a big box added to the rear curve of an existing 14" can. The exact shape is not significant, it's just a buffer plenum.
Boffin Emeritus
