Measurements for mounting drive shaft loop? A-body #2547023
09/07/18 01:19 AM
09/07/18 01:19 AM
Wisconsin
wkroncke17 Offline OP
Wisconsin
All,
I bought one of the driveshaft loops made by Metco Motorsports.
Very nice, quality piece.
So the car is on a rotisserie right now (72 Demon) and I’d like to drill the holes before the bottom is painted.
What I would like to know is how far behind the tail shaft do I mount the loop?
The measurement I need (since there’s no transmission in the car) is how far back from the back of the trans mount do I place it to drill the holes??
I’m going to be using 904 transmission if that makes a difference???
Thanks in advance!!
Wally.
Re: Measurements for mounting drive shaft loop? A-body [Re: wkroncke17] #2547044
09/07/18 02:34 AM
09/07/18 02:34 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
nhra wants it 6 in from c/l of u joint last time i recall ?
Re: Measurements for mounting drive shaft loop? A-body [Re: calrobb2000] #2547201
09/07/18 02:05 PM
09/07/18 02:05 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
FWIW,has anybody seen an inspector measure the NHRA specified dim other then by eye? work
Re: Measurements for mounting drive shaft loop? A-body [Re: wkroncke17] #2547257
09/07/18 04:27 PM
09/07/18 04:27 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
NHRA wants it no more than 6" away from the joint. Never seen it measured, but I've seen what happens when one gets loose at speed. NHRA specs are a minimum. I build them to satisfy me.
Re: Measurements for mounting drive shaft loop? A-body [Re: wkroncke17] #2547262
09/07/18 04:48 PM
09/07/18 04:48 PM
Rochester, PA (near Pittsburgh...
1974 474 Duster Offline
Never been inspected either. Just go from the center of the U-joint out approx. 6". Keep it as close to that as possible. Keeps the carnage of an expired U-joint in the car. Don't want to give that driveshaft to much room to bounce around.
Re: Measurements for mounting drive shaft loop? A-body [Re: wkroncke17] #2547418
09/07/18 11:21 PM
09/07/18 11:21 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
My “universal” hoop fit my 2” chromoly shaft ok, but was a bit close to my 3.5” aluminum piece. I sectioned it and welded in 2 pieces to widen it. Hope I never have to test it
Re: Measurements for mounting drive shaft loop? A-body [Re: wkroncke17] #2547752
09/08/18 11:28 PM
09/08/18 11:28 PM
Wisconsin
Wisconsin
Gotcha. Thanks for the replies all.
If anyone has one built to this spec on an A-body, is there a chance I could get a measurement from the back of the trans cross member to the loop?
My Demon is still on a rotisserie and want to drill the holes before paint.
Thank you in advance!
