Re: Can use some advice with a new engine build ( HEMI)
[Re: hudsonhornet7x]
#2546926
09/06/18 09:39 PM
09/06/18 09:39 PM
Posts: 12,327 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Call Ray Barton. He can spec in your reciprocating assembly and cam.
Master, again and still
#2546995
09/07/18 12:12 AM
09/07/18 12:12 AM
Posts: 2,691 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
No good reason to start with less 4.500" bore. It's free power. And it helps everything. And there will still be enough cleanup room to last a lifetime. And a 4.150" crank. That will be a 528. The last one I built was a 4.250" bore. What a bad idea. I had a new rotating assembly laying there so I thought I should use it. I should have thrown it in the trash. More cubic, better heads and modern pistons are why Hemi's are 800 HP today instead of 425 HP. Don't put together a dog.
2011 Drag Pak Challenger
[Re: rickseeman]
#2547000
09/07/18 12:24 AM
09/07/18 12:24 AM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
Those Edelbrock heads are stupid cheap (like wedge price complete) too and I think they work better with a 4.5 bore? I ran 426's for decades and the stroker deal is what really makes a Hemi work nice on the street. I've built 472's and 528's and either work better for a street car than a 426 obviously.
Sheldon
#2547149
09/07/18 12:26 PM
09/07/18 12:26 PM
Posts: 4,213 New York
polyspheric
New York
Larger bore makes more effective quench.
Boffin Emeritus
#2547195
09/07/18 01:50 PM
09/07/18 01:50 PM
rickseeman
Stuttgart, Arkansas
I've never heard them say how much power they can handle but as you said it's a lot more than you or I plan on making.
