BB MOTORPLATE #2546436
09/05/18 11:03 PM
09/05/18 11:03 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Anything to know when using a motorplate? Water pump? Balancer? Alternator? Pulleys? Anything else?
Re: BB MOTORPLATE [Re: A/MP] #2546446
09/05/18 11:31 PM
09/05/18 11:31 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
that is something for me as well .
I know you need limiters , fore & aft movement .
Andy does a plate and crank pulley spacer , Can you run a stock style alternator ? Low mount ? DMI show a low mount kit
I think Magnumforce do a high , left side , alternator mount .
sorry for the hijack
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: BB MOTORPLATE [Re: tex013] #2546455
09/05/18 11:44 PM
09/05/18 11:44 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
You just need to got to AR Engineering and see all the cool stuff for motor plate installation. I just used the crank pulley spacer and the low mount alternator kit for the Denso alternator.
Gus beer
64 Plymouth Savoy
Dana 60
Re: BB MOTORPLATE [Re: A/MP] #2546480
09/06/18 12:27 AM
09/06/18 12:27 AM
I have the water pump housing machined the thickness of the plate or elephant ears so all the pulleys align properly up scope
I have not had to add a fore and aft travel limiter either using a stock tranny mount shruggy
That being said, maybe I should have work confused shruggy
Re: BB MOTORPLATE [Re: A/MP] #2546505
09/06/18 01:09 AM
09/06/18 01:09 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I never had the horizontal limiters.It seems fine with the thick motorplate and just the midplate.The motorplate also spaces my waterpump out giving me good clearance for the gear drive.I've seen some sanitary limiters from the trans to the trans crossmember.
If you are fabbing the engine plate & midplate at the same time,,,,,,set your engine back as far as you can!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: BB MOTORPLATE [Re: A/MP] #2546512
09/06/18 01:20 AM
09/06/18 01:20 AM
hemi-itis Offline
hemi-itis  Offline
I used this to low mount my full sized GM alternator.
https://www.jegs.com/i/JEGS/555/50542/10002/-1
Re: BB MOTORPLATE [Re: hemi-itis] #2546516
09/06/18 01:30 AM
09/06/18 01:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The limiters help a lot specially on a race car..
I ran just the motor plate and a mid plate and
it would bang the engine off the trans bushing
till it broke and it was pushing in on the trans
so I added the limiters.. was a big help and I
never broke another trans mount
wave
Re: BB MOTORPLATE [Re: A/MP] #2546593
09/06/18 10:24 AM
09/06/18 10:24 AM
an8sec70cuda Offline
Definitely need a fore-aft limiter of some sort. You can always leave one factory motor mount on it to act as a limiter. That's what I did on my B body...the passenger's side factory motor mount is easy to get to and not in the way of headers, so I left it there to serve as a limiter.
A midplate isn't a necessity, but they aren't a bad idea if you have room for one. I don't run one on my cuda.
Low mount alternator kit is the way to go. I use the DMI kit, but AndyF has some nice ones too.
Make sure your frame brackets are located BEHIND the motorplate.
I set my water pump housing up on the head surfacer and cut it down to offset some of the distance the motorplate spaced it out. Not necessary if you run an electric pump, but it helps w/ packaging if you run a big alternator and fan.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: BB MOTORPLATE [Re: A/MP] #2546601
09/06/18 10:56 AM
09/06/18 10:56 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Originally Posted By an8sec70cuda
Definitely need a fore-aft limiter of some sort.....
good advice!!!
I run the fore-aft limiter from the frame to the motor mount tabs on the block. there may be a better spot to mount it on the block or trans, but the options are limited with so little room.
Not sure which plate OP will be using, but another benefit to having the frame brackets behind the plate is that switching to a thicker plate won't push the motor back.
Re: BB MOTORPLATE [Re: A/MP] #2546627
09/06/18 12:18 PM
09/06/18 12:18 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have both a front plate & a mid plate on my Challenger. I made some for/aft mounts to the trans cross member since there is do little room left in the engine bay with the Hemi & big tube headers.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: BB MOTORPLATE [Re: A/MP] #2546858
09/06/18 07:38 PM
09/06/18 07:38 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Studs or bolts for waterpump / plate ?
Looks like studs would be easier for locating gaskets etc .
Does ARP do a kit ?
thanks
Tex
New best MPH 130.32
Re: BB MOTORPLATE [Re: tex013] #2546945
09/06/18 10:35 PM
09/06/18 10:35 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Tends to flop around a little if you don't bolt it down with all three holes in the bracket....like this.I also flattened out the other small bracket and use that as a backing plate behind the aluminum motor plate.
