PCV valve? #2545646
09/04/18 02:04 PM
09/04/18 02:04 PM
ny
marcjames Offline OP
ny
1967 440 hp motor is it better to run a pvc valve or just a breather cap thanks mark motor is a 511 stroker
Re: PCV valve? [Re: marcjames] #2545655
09/04/18 02:10 PM
09/04/18 02:10 PM
Run a PCV & depending on the vac level you may or may not need to fine tune it. there was a good thread way back on different PCV's that I shoulda saved (I gotta get my printer going). For starters run one.
Re: PCV valve? [Re: marcjames] #2545730
09/04/18 05:04 PM
09/04/18 05:04 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I always use a pcv on one VC and a breather on the other VC. I am far from being a expert but it has always worked for me.
Re: PCV valve? [Re: mopars4ever] #2545834
09/04/18 08:52 PM
09/04/18 08:52 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
If you JUST run one or the other, it's ALWAYS better to run just a breather.
