Re: viper caliper adapters
[Re: DoctorDiff]
#254456
03/17/09 11:19 AM
03/17/09 11:19 AM
Posts: 4,244 Canada
Kam*Kuda
Canada
What size rim would you need to use?
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: phil4161972]
#254462
03/17/09 02:43 PM
03/17/09 02:43 PM
Stock 15" steelies and cop rims will clear but 15" Ralley's won't. It has to do with the lip on the rim interfering.
#254464
03/17/09 05:03 PM
03/17/09 05:03 PM
Posts: 31,199 Oregon
AndyF
Right, Ralley's don't fit and early drum brake rims don't fit. Some of the aftermarket reproduction stuff won't fit but most late model steel rims do fit. I just assumed when I designed that kit that anyone who is putting Viper brakes on their car wasn't going to be using steel rims but I found out otherwise. Seems there are guys out there who wanted to run the Viper calipers in "stealth" mode behind factory style rims.
[Re: DoctorDiff]
#254465
03/17/09 05:23 PM
03/17/09 05:23 PM
Posts: 4,027 Dearborn Hts, MI
Sledge_57
Dearborn Hts, MI
Looks like I misread the orignal post.
My spindle sleeves will adapt Andy's 11.75" Viper kit to a B/E body DRUM knuckle, or his 13" Viper kit to a '70-'72 disc knuckle. He doesn't make 11.75" caliper brackets for the disc knuckle.
'73-'76 A-body drum knuckles are identical to the earlier B-body drum knuckles, except they take the larger, late model inner bearing and seal.
Sorry about that. You can return the parts I just sent you, Phil.
So I'm confused a bit (as usual) to put these on a 67 B body do I need your sleeves, new knuckles or.............?
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
