viper caliper adapters #254451
03/15/09 03:29 PM
03/15/09 03:29 PM
NC
P
phil4161972 Offline OP
P
NC
will the brakets to bolt viper calipers on with the 11.75 rotor bolt to a 70-72 ebody disc brake spindle? thanks
Re: viper caliper adapters [Re: phil4161972] #254452
03/15/09 03:38 PM
03/15/09 03:38 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
It will work if you use my spindle sleeve and seal package.
Re: viper caliper adapters [Re: DoctorDiff] #254453
03/15/09 03:40 PM
03/15/09 03:40 PM
NC
P
P
NC
thats what i was thinking about doing. i just wanted to make sure those brakets would bolt up
Re: viper caliper adapters [Re: phil4161972] #254454
03/16/09 09:30 PM
03/16/09 09:30 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
Who makes the brackets?
Re: viper caliper adapters [Re: Dos Snails] #254455
03/16/09 10:52 PM
03/16/09 10:52 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
AndyF (AR Engineering) makes the brackets.
Re: viper caliper adapters [Re: DoctorDiff] #254456
03/17/09 11:19 AM
03/17/09 11:19 AM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
What size rim would you need to use?
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: viper caliper adapters [Re: Kam*Kuda] #254457
03/17/09 01:08 PM
03/17/09 01:08 PM
AndyF Offline
AndyF  Offline
Most 15 inch disc brake rims fit.
Re: viper caliper adapters [Re: AndyF] #254458
03/17/09 01:34 PM
03/17/09 01:34 PM
NC
P
P
NC
i keep looking and it seems there is only a bracket to make the gen 1 viper calipers fit on the 11.75 rotor, am i correct on this?
Re: viper caliper adapters [Re: phil4161972] #254459
03/17/09 01:48 PM
03/17/09 01:48 PM
AndyF Offline
AndyF  Offline
I make a bracket kit to hang the early Viper calipers and 11.75 rotors onto late model drum brake knuckles. I don't know if anyone else sells something similiar or not.
Re: viper caliper adapters [Re: AndyF] #254460
03/17/09 02:16 PM
03/17/09 02:16 PM
NC
P
P
NC
ok so will that bracket bolt onto a 70-72 ebody disc spindle? and out of curiousity how are you putting the 73 up rotor on the drum brake spindle?
Re: viper caliper adapters [Re: phil4161972] #254461
03/17/09 02:40 PM
03/17/09 02:40 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Looks like I misread the orignal post.
My spindle sleeves will adapt Andy's 11.75" Viper kit to a B/E body DRUM knuckle, or his 13" Viper kit to a '70-'72 disc knuckle. He doesn't make 11.75" caliper brackets for the disc knuckle.
'73-'76 A-body drum knuckles are identical to the earlier B-body drum knuckles, except they take the larger, late model inner bearing and seal.
Sorry about that. You can return the parts I just sent you, Phil.
Re: viper caliper adapters [Re: phil4161972] #254462
03/17/09 02:43 PM
03/17/09 02:43 PM
Stock 15" steelies and cop rims will clear but 15" Ralley's won't. It has to do with the lip on the rim interfering.
Re: viper caliper adapters [Re: phil4161972] #254463
03/17/09 04:59 PM
03/17/09 04:59 PM
AndyF Offline
AndyF  Offline
The bracket kit fits 1973 or newer drum brake knuckles. Just buy some drum knuckles from a late model A body car and bolt them on. There are posts on here every day from A body guys who want to upgrade from drum brakes to disc brakes so the drum knuckles are certainly available.
11.75 disc brake rotors fit just fine on late model drum brake spindles.
Re: viper caliper adapters #254464
03/17/09 05:03 PM
03/17/09 05:03 PM
AndyF Offline
AndyF  Offline
Right, Ralley's don't fit and early drum brake rims don't fit. Some of the aftermarket reproduction stuff won't fit but most late model steel rims do fit. I just assumed when I designed that kit that anyone who is putting Viper brakes on their car wasn't going to be using steel rims but I found out otherwise. Seems there are guys out there who wanted to run the Viper calipers in "stealth" mode behind factory style rims.
Re: viper caliper adapters [Re: DoctorDiff] #254465
03/17/09 05:23 PM
03/17/09 05:23 PM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
So I'm confused a bit (as usual) to put these on a 67 B body do I need your sleeves, new knuckles or.............?
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: viper caliper adapters [Re: Sledge_57] #254466
03/17/09 05:44 PM
03/17/09 05:44 PM
AndyF Offline
AndyF  Offline
1973 or newer drum brake knuckles. If that is what you have on the car then just bolt on the brackets, slide on the rotors and you're done.
Re: viper caliper adapters [Re: Sledge_57] #254467
03/17/09 08:05 PM
03/17/09 08:05 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Yes, you can also use my spindle sleeves to install the 11.75" Viper kit on '72 and earlier B-body drum knuckles.
Re: viper caliper adapters [Re: DoctorDiff] #254468
03/18/09 12:06 AM
03/18/09 12:06 AM
Escondido, CA
kick_the_reverb Offline
Escondido, CA
Hmmm!!! Your post and Andy's last post just made me realize that it might be possible to use this on an A-100 spindle (for 10" brakes) - the bolt pattern looks like the A-100 spindle (which is like the mid 60's B-body), and your sleeves will allow the installation of the 11.75" rotor.
Not sure that I would need Viper calipers on an A-100, but it's nice to know the option might be there.
So if I understand correctly - 73-76 A body drum backing plate bolt pattern is the same as mid 60's B-body 10" backing plate bolt pattern?
Thanks,
Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto
Finally - disc brakes on the front.
In the plans - rear disc brakes, B&M 250 blower
Re: viper caliper adapters [Re: kick_the_reverb] #254469
03/18/09 12:23 AM
03/18/09 12:23 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Yes, brakes are different but the balljoint and backing plate bolt pattern is the same.
Re: viper caliper adapters [Re: DoctorDiff] #254470
03/18/09 03:36 AM
03/18/09 03:36 AM
Escondido, CA
Escondido, CA
Cool, thanks!
