D350 Rear Ratio? #2544031
08/31/18 11:15 PM
08/31/18 11:15 PM
Alexandria, LA
Blucuda413 Offline OP
Alexandria, LA
What was the standard gear ratio in a 88 D350 powered by a 360??
Re: D350 Rear Ratio? [Re: Blucuda413] #2544050
08/31/18 11:55 PM
08/31/18 11:55 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
What gear?
Axle?
First gear of the trans? 727 or 4 speed? 4 Speed with granny low?
Re: D350 Rear Ratio? [Re: Blucuda413] #2544055
09/01/18 12:03 AM
09/01/18 12:03 AM
Wills Point, Texas
Hugh Jorgan Online work
Hugh Jorgan  Online Work
Wills Point, Texas
The dreaded 4:10.
Here's a good deal on some 3:54s....
https://easttexas.craigslist.org/pts/d/1993-dodge-diesel-ring-and/6684182157.html
Re: D350 Rear Ratio? [Re: Blucuda413] #2544058
09/01/18 12:05 AM
09/01/18 12:05 AM
STL ,MO
Handygun Offline
Handygun  Offline
STL ,MO
My 88 360-4v/435 truck was a 4.56 but it was a c/c
Re: D350 Rear Ratio? [Re: Blucuda413] #2544119
09/01/18 02:48 AM
09/01/18 02:48 AM
Alexandria, LA
Alexandria, LA
The reason for my question is that I'm going to look at an 88 this weekend and if it's nice enuff I may buy it. My only experience is more than 20 yrs ago I had a 85 D350 with a 360 and it was an extremely strong combo. That old truck had been used up as a wrecker and was in terrible shape except for the running gear. My son used in it calif to tow his race car to LACR and there were none of his friends 454 Chev duallies that could keep up with him going up the grapevine. The thing was great for a 360. I hope this one I'm going to look at will be close in performance.
Re: D350 Rear Ratio? [Re: Blucuda413] #2544450
09/01/18 11:20 PM
09/01/18 11:20 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Probably a 4.10 as 3.54 would be the only other gear offered. There should be a data sheet affixed to the underside of the hood. wave
JB Rhinehart, Realist
A-Body's RULE!
Re: D350 Rear Ratio? [Re: Rhinodart] #2544592
09/02/18 12:52 PM
09/02/18 12:52 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
there were three ratios available, 4.10, 4.56 and 4.88. none were "standard" there should be a label on the hood that will tell you what ratio came with the truck, also there is a tag in the diff cover.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: D350 Rear Ratio? [Re: Rhinodart] #2545074
09/03/18 01:22 PM
09/03/18 01:22 PM
ky.
K
kenworth_goose Offline
K
ky.
That would be correct for the 89 and up trucks but the 3.54 wasn't available in the 1 tons until 89. Or until the cummins came out.
Re: D350 Rear Ratio? [Re: kenworth_goose] #2545544
09/04/18 10:39 AM
09/04/18 10:39 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
OK, I stand corrected. My 84 crew cab dually has 4.10's, but I am sure they were changed at some point. wave
A-Body's RULE!
Re: D350 Rear Ratio? [Re: W.I.N. Racing] #2545844
09/04/18 09:25 PM
09/04/18 09:25 PM
Byron, NY
Byron, NY
^^^This info came direct from a 1986 Dodge Service manual^^^ All ratios were spec'd by Eng/trans combo.
Wait this just in...found my '92 service manual!
First just for clarity... all specs below are for D350 DRW and a Dana 70.
The gear options in '92 were...3.54, 4.1 and 4.56
This is due to the 46RH OD trans.
89-91 (non intercooled) had 3.07 with the 727 only and 3.54 & 4.10's with manual trans.
All the above information is supported by the Chrysler service manuals for the given year stated.
'60 Willys CJ5
