Re: Low band apply valve body.
[Re: bonefish]
#2543887
08/31/18 03:20 PM
08/31/18 03:20 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
i love my lba. just be REAL carefull not to accidentally down shift to first unless your goin REAL slow. I have an A1 LB apply trans brake valve body I will put in someday. I have driven a non LBA Cheetah VB on the street for 20 years, its going to be a tough change I am sure.
68 Barracuda Formula S 340
[Re: bobby66]
#2544089
09/01/18 01:20 AM
09/01/18 01:20 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Still running a 400 in that green Dart? Yes it still has the 406 (.030 over 400) in it. It uses the MP .557 cam and has KB pistons as its right at 10.6 comp as we had the RPM heads milled some. Has the RPM dual plane intake and a 750 DP. Its 3.91 gears and a Dynamic 9.5 street/strip converter. The last time it was at the track was about a year ago when he ran his best et of 11.41 @ 117. Its not a lightweight as it weighs just over 3600 lbs with his 180 in it. Ron
[Re: Bad340fish]
#2544091
09/01/18 01:24 AM
09/01/18 01:24 AM
383man
Balt. Md
i love my lba. just be REAL carefull not to accidentally down shift to first unless your goin REAL slow. I have an A1 LB apply trans brake valve body I will put in someday. I have driven a non LBA Cheetah VB on the street for 20 years, its going to be a tough change I am sure. Me to and I still run my no low band apply manual valve body on the street. I do have a trans blanket on mine as my son does not so I feel better with the low band apply V/B in his car. Ron
