Re: Need a recommendation for a set of solid roller lifters
[Re: Sammy]
#2542719
08/28/18 08:26 PM
08/28/18 08:26 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Typically, the “correct” oil feed location for a bb Mopar is having them parallel to the axles, and above the band.
Hopefully the place that installed the bushings didn’t put “giant” holes in the bushings. A .030 feed hole is more than enough.
[Re: Sammy]
#2543136
08/29/18 05:16 PM
08/29/18 05:16 PM
Posts: 74,976 U.S.S.A.
JohnRR
U.S.S.A.
I tried comp elites and crowes, these lifters seem to be for oil galleys facing outward. OIL is hemmoraging out through the lifter bore, I need a lifter designed for the indy aluminum block What size is the bore , what size is the lifter ... what size is the hole in the bushing ?
[Re: Sammy]
#2543144
08/29/18 05:49 PM
08/29/18 05:49 PM
Posts: 11,709 Portage,michigan
B3422W5
Portage,michigan
I know back when Best did my smallblock Chuck liked the Crane Ultra pro’s i had bought for the build. Had such good luck with those i wouldnt use anything else
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Sammy]
#2543174
08/29/18 06:42 PM
08/29/18 06:42 PM
fast68plymouth
So. Burlington, Vt.
How about a couple pics of what isn’t working?
