Page 4 of 4 1 2 3 4
Re: How much are my small headers killing my performance [Re: Plymouth340] #2543019
08/29/18 01:59 PM
08/29/18 01:59 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Originally Posted By Plymouth340
Originally Posted By pittsburghracer
From everything I've read and heard about this engine combo I would lean towards the converter not being the right stall. That seems to be the biggest issues
Well I finally put in a 7 inch converter and it picked up all most 2 tenths..9.07 @ 149 in 4000 da air..that was the ticket and I haven't tried leaving at higher rpm yet or a little more jet
Very nice!!!!!!!
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: How much are my small headers killing my performance [Re: Al_Alguire] #2543060
08/29/18 03:03 PM
08/29/18 03:03 PM
CEDAR RAPIDS
Plymouth340 Offline OP
CEDAR RAPIDS
Originally Posted By Al_Alguire
FWIW the smallblock in the heads up car made over 1000 with a set of 1 7/8" 20 long primary headers on the dyno. Headers on the car are 1 7/8 to 2 to 2 /18". Car ran 8.0's last year at 2800.
had some headers built...1 7/8-2 1/8-2 1/4..didnt see much performance diff..converter made all the diff
Re: How much are my small headers killing my performance [Re: Thumperdart] #2543062
08/29/18 03:04 PM
08/29/18 03:04 PM
CEDAR RAPIDS
CEDAR RAPIDS
What carb(s) are you running............
one 1200 cfm
Re: How much are my small headers killing my performance [Re: Plymouth340] #2543394
08/30/18 12:27 PM
08/30/18 12:27 PM
gregsdart Online content
gregsdart  Online Content
I agree on the horsepower being in the 700 range with current setup,given a decent chassis. First off, you say peak power is 9,000 and you shift at 8700? Peak torque is 7200 and stall is 7,000?
My deal makes peak power at 6900, and shift at 7450 and 2/3 at 7300, stall is 6200, but peak torque is 5,000! I dynoed the motor and it said 847 hp, car weighs 3065, i use 2078 Goodyear slicks that weigh 41 lbs each, and the car went 8.900 at 2100 da.
The point of all this info is if ypur tq and hp peaks are what you say, the stall and shift points may be a big part of the problem. Too low. Its dyno time! Get the real dope on the motor and go from there.
Page 4 of 4 1 2 3 4
