Crank gridle sealer #2542945
08/29/18 11:07 AM
08/29/18 11:07 AM
La.USA
rick4106 Offline OP
rick4106  Offline OP
La.USA
What sealer are you using between block and crank gridle
Re: Crank gridle sealer [Re: rick4106] #2542998
08/29/18 01:22 PM
08/29/18 01:22 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I use motoseal, it's designed for metal to metal cases on motorcycles. Basically a real thin rtv
https://shop.advanceautoparts.com/p/perm...29132/7740017-P
Re: Crank gridle sealer [Re: rick4106] #2543680
08/31/18 01:39 AM
08/31/18 01:39 AM
La.USA
rick4106 Offline OP
rick4106  Offline OP
La.USA
Anybody use Permatex black ultra seal
Re: Crank gridle sealer [Re: rick4106] #2543703
08/31/18 02:48 AM
08/31/18 02:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have used Right Stuff.. just a thin layer
wave
Re: Crank gridle sealer [Re: MR_P_BODY] #2544016
08/31/18 10:28 PM
08/31/18 10:28 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Permatex Ultra grey. up
Re: Crank gridle sealer [Re: rick4106] #2544840
09/02/18 11:22 PM
09/02/18 11:22 PM
Nevada
merpar Offline
merpar  Offline
Nevada
Best situation would be, if girdle fits between pan and block. Throw the girdle away and use a pan gasket. Then you're done. A girdle that goes between pan and block does absolutely no good.
Re: Crank gridle sealer [Re: rick4106] #2545002
09/03/18 11:39 AM
09/03/18 11:39 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
this is what i use, follow the directions and allow a "skin" to build before torquing the main stud nuts.
Joe
Without Data, you’re just another guy with an opinion.
