Re: Lil wheelie
[Re: KDY]
#2542759
08/28/18 09:46 PM
08/28/18 09:46 PM
Posts: 428 Mountain City, TN
JesseR
Mountain City, TN
I’m glad that hood found a new home. It’s a 396 small block with Indy’s. I kicked a rod through the 499 block and went back to my small block roots. We’re just trying to dial it in to run 6.0 index stuff. I’ve not had enough passes with it yet to get it settled down, we were just surprised it left the way it did on only 12 degrees of timing
82' dodge pickup with a 499 low deck
Re: Lil wheelie
[Re: JesseR]
#2542765
08/28/18 10:10 PM
08/28/18 10:10 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
It’s a 396 small block with Indy’s. I kicked a rod through the 499 block and went back to my small block roots. .. welcome back..looks about right to me. Keep up the good work... you will make the people in the stands happy
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: Lil wheelie
[Re: JesseR]
#2542772
08/28/18 10:32 PM
08/28/18 10:32 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I’m glad that hood found a new home. It’s a 396 small block with Indy’s. I kicked a rod through the 499 block and went back to my small block roots. We’re just trying to dial it in to run 6.0 index stuff. I’ve not had enough passes with it yet to get it settled down, we were just surprised it left the way it did on only 12 degrees of timing Is this a NA combo and if so why 12 degrees timing.
Re: Lil wheelie
[Re: pittsburghracer]
#2542796
08/28/18 11:18 PM
08/28/18 11:18 PM
JesseR
Mountain City, TN
That was leaving on 175 hp of nitrous, I’m new to the programmable ignition box. I’ve always just used a timer to turn it on, so this is a learning curve for me. Nothing hurt at all, I just new I was getting close to the centerline. It went 6.08 off the trailer, we’re just looking to run some 5.90/ 6.0 index stuff around here. It’s got a 727 in it now, but my glide is sitting here ready to go in. We may tinker with it for a while with the 3 speed, but the glide will make things much more manageable
Re: Lil wheelie
[Re: JesseR]
#2542804
08/28/18 11:43 PM
08/28/18 11:43 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
That was leaving on 175 hp of nitrous, I’m new to the programmable ignition box. I’ve always just used a timer to turn it on, so this is a learning curve for me. Nothing hurt at all, I just new I was getting close to the centerline. It went 6.08 off the trailer, we’re just looking to run some 5.90/ 6.0 index stuff around here. It’s got a 727 in it now, but my glide is sitting here ready to go in. We may tinker with it for a while with the 3 speed, but the glide will make things much more manageable Ok thanks that makes more sense. I may get my 3 bottles filled at Norwalk this weekend and try nitrous for my first time. I want to get a mother bottle but its to late in the year for that. I would just like to get my feet wet. LOL
Re: Lil wheelie
[Re: Cab_Burge]
#2542841
08/29/18 01:07 AM
08/29/18 01:07 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
That sounds like a story I use to tell girls I dated AKA aside, you know what is said about NOS, one use and your addicted [/quote] I hope so!!!!!!!!!! Untitled by John Cadamore, on Flickr
Re: Lil wheelie
[Re: JesseR]
#2543070
08/29/18 03:22 PM
08/29/18 03:22 PM
Posts: 13,416 Marion, South Carolina [><]
an8sec70cuda
Glad to see you back at it Jesse!
Re: Lil wheelie
[Re: an8sec70cuda]
#2543121
08/29/18 04:48 PM
08/29/18 04:48 PM
JesseR
Mountain City, TN
Thanks man! It’s good to be making some laps again, now if I can get it all one color again!
