Re: Sliders Install [Re: 360tripleblack77] #2543159
08/29/18 06:16 PM
08/29/18 06:16 PM
P
Porter67 Offline
Porter67  Offline
P
How old are your springs? I think you will be ok as they will settle a bit more, esp if they are claverts springs.
Re: Sliders Install [Re: 360tripleblack77] #2543193
08/29/18 07:23 PM
08/29/18 07:23 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Originally Posted By 360tripleblack77
Nice!! I'll do that tonight and post a picture here tomorrow.
Thanks Shiloh
.. like most have said they should have been mounted a little further Forward. But I think you will be fine. You can rub some grease on the slider to see how far the The roller moves .I can tell you with a quality shock you will get less separation and less movement in the rear. With my setup I get less than 3/4 inch of movement on the roller now.
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Sliders Install [Re: 360tripleblack77] #2543252
08/29/18 11:16 PM
08/29/18 11:16 PM
ma.
duspan Offline
duspan  Offline
ma.
whats better the slider or a shackle? street/strip car
Re: Sliders Install [Re: Porter67] #2543344
08/30/18 09:06 AM
08/30/18 09:06 AM
Gravataí, RS, Brazil
360tripleblack77 Offline OP
Springs are brand new calvert split monoleafs.
'77 Brazilian Dodge Charger R/T - Street Car
Footbrake, Pump Gas, SB Mopar 360" N/A
3300lbs, Leaf Spring + Assassin Bars
Best 1/8 mile ET
1.50 60' / 4.31 330' / 6.73@102.54mph
Re: Sliders Install [Re: WHITEDART] #2543346
08/30/18 09:20 AM
08/30/18 09:20 AM
I agree with you... Maybe moving 1" forward the slider will be perfect. I'm running with Viking DA shocks that should provide less separation (I hope). I will rub some grease and make a movie with my GoPro camera to check the clearance and separation. I see that Calvert spring has less separation than OEM springs So I hope that slider slot will have clearance enough to keept welded in the same place. Let's check it out soon.. punkrocka
Thanks Man!
Best 1/8 mile ET
Re: Sliders Install [Re: 360tripleblack77] #2543348
08/30/18 09:40 AM
08/30/18 09:40 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
just drill a new hole 1.5"back in the rear spring segment for the centering bolt.
Re: Sliders Install [Re: 360tripleblack77] #2543359
08/30/18 10:34 AM
08/30/18 10:34 AM
Ohio
lockjaw-express Offline
Ohio
I have the Calvert Racing Sliders, and originally set them at 70% toward the back, and due to setteling they are now 80% back. So if your springs are new, I would take that into consideration.
Re: Sliders Install [Re: duspan] #2543382
08/30/18 11:42 AM
08/30/18 11:42 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Calvert does not recommend theirs for the street.
Re: Sliders Install [Re: 340Cuda] #2543407
08/30/18 12:59 PM
08/30/18 12:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
They will clunk and clang on the street(with
a decent exhaust you will hear them).. anything
that isnt rubber isolated will make some noise..
if you use them they need to be cleaned and lubed
on a regular basis.. same as ladder bars or any
other parts that are steel on steel
wave
Re: Sliders Install [Re: CSK] #2543745
08/31/18 09:33 AM
08/31/18 09:33 AM
I liked it! Easy to fix!
Best 1/8 mile ET
