Re: Sliders Install
[Re: 360tripleblack77]
#2543193
08/29/18 07:23 PM
08/29/18 07:23 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Nice!! I'll do that tonight and post a picture here tomorrow.
Thanks Shiloh .. like most have said they should have been mounted a little further Forward. But I think you will be fine. You can rub some grease on the slider to see how far the The roller moves .I can tell you with a quality shock you will get less separation and less movement in the rear. With my setup I get less than 3/4 inch of movement on the roller now.
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: Sliders Install
[Re: Porter67]
#2543344
08/30/18 09:06 AM
08/30/18 09:06 AM
Posts: 192 Gravataí, RS, Brazil
360tripleblack77
Springs are brand new calvert split monoleafs.
'77 Brazilian Dodge Charger R/T - Street Car Footbrake, Pump Gas, SB Mopar 360" N/A 3300lbs, Leaf Spring + Assassin Bars Best 1/8 mile ET 1.50 60' / 4.31 330' / 6.73@102.54mph
Re: Sliders Install
[Re: WHITEDART]
#2543346
08/30/18 09:20 AM
08/30/18 09:20 AM
360tripleblack77
I agree with you... Maybe moving 1" forward the slider will be perfect. I'm running with Viking DA shocks that should provide less separation (I hope). I will rub some grease and make a movie with my GoPro camera to check the clearance and separation. I see that Calvert spring has less separation than OEM springs So I hope that slider slot will have clearance enough to keept welded in the same place. Let's check it out soon.. Thanks Man!
Re: Sliders Install
#2543348
08/30/18 09:40 AM
08/30/18 09:40 AM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
just drill a new hole 1.5"back in the rear spring segment for the centering bolt.
Re: Sliders Install
[Re: duspan]
#2543382
08/30/18 11:42 AM
08/30/18 11:42 AM
Posts: 3,527 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
whats better the slider or a shackle? street/strip car Calvert does not recommend theirs for the street.
Re: Sliders Install
[Re: 340Cuda]
#2543407
08/30/18 12:59 PM
08/30/18 12:59 PM
Posts: 52,972 Romeo MI
MR_P_BODY
whats better the slider or a shackle? street/strip car Calvert does not recommend theirs for the street. They will clunk and clang on the street(with a decent exhaust you will hear them).. anything that isnt rubber isolated will make some noise.. if you use them they need to be cleaned and lubed on a regular basis.. same as ladder bars or any other parts that are steel on steel ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
