"The Block" - Such a pretty sight........... #2541665
08/26/18 06:30 PM
08/26/18 06:30 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
After disassembling the short block due to issues, my motor is done!
Its a new "The Block" RB 505 with Trick Flow 270 heads, 337 intake and one of Dwayne's solid roller cams. Its for my 69 GTX street/strip new build.
Should hit the dyno next week. Hopefully the power numbers won't disappoint.
PS - I hate computers. The picture is not sideways on my computer.
Re: "The Block" - Such a pretty sight........... [Re: markz528] #2541688
08/26/18 07:26 PM
08/26/18 07:26 PM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
Argh
if only I could get 1 of these !
I would buy 1 in a flash
What sort of issues ?
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: "The Block" - Such a pretty sight........... [Re: markz528] #2541690
08/26/18 07:31 PM
08/26/18 07:31 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
What block is it?
[image][/image]
Re: "The Block" - Such a pretty sight........... [Re: sgcuda] #2541693
08/26/18 07:40 PM
08/26/18 07:40 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Originally Posted By sgcuda
What block is it?
Its the new "The Block" made by the fellow from Chicago Connection with a bunch of other fingers in the pot.........
Issues included:
Cam would not go in - the cam bearing bores are tight
Dipstick hole too tight
Lifter bores - let's just say they were no good
Distributor gear drive would not go in - gear was hitting the block
Minor clearance issues on some oil plugs
Tony Bischoff (BES) fixed it and assembled the motor. He is good and knows how to make power.
Re: "The Block" - Such a pretty sight........... [Re: markz528] #2541697
08/26/18 07:46 PM
08/26/18 07:46 PM
Sydney,Australia
Sydney,Australia
Thanks markz528
Tex
New best MPH 130.32
Re: "The Block" - Such a pretty sight........... [Re: markz528] #2541724
08/26/18 08:19 PM
08/26/18 08:19 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Re: "The Block" - Such a pretty sight........... [Re: BigBlockMopar] #2541726
08/26/18 08:22 PM
08/26/18 08:22 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Originally Posted By BigBlockMopar
I'm in work - W10 screws me up. I will fix my pic with my W7 machine when I get home.
Re: "The Block" - Such a pretty sight........... [Re: markz528] #2541946
08/27/18 11:38 AM
08/27/18 11:38 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Porter never disappoints!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: "The Block" - Such a pretty sight........... [Re: markz528] #2541956
08/27/18 11:49 AM
08/27/18 11:49 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Whos breathers are those.. I like them.. the
engine looks good also
wave
Re: "The Block" - Such a pretty sight........... [Re: markz528] #2541964
08/27/18 12:09 PM
08/27/18 12:09 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Looks good....... but I would have gone in a different direction for the block color😉
Are you going to use the car headers, or do they have dyno headers?
Just wondering what size will be used for testing.
Did they do any more to the manifold besides port matching?
Re: "The Block" - Such a pretty sight........... [Re: markz528] #2541966
08/27/18 12:11 PM
08/27/18 12:11 PM
an8sec70cuda Offline
Nice! Hope it works out good on the dyno!
Never understood why someone would completely assemble an engine like that when the block needs painting...considering most don't want to paint brand new aluminum heads, new balancer, etc.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: "The Block" - Such a pretty sight........... [Re: an8sec70cuda] #2541975
08/27/18 12:21 PM
08/27/18 12:21 PM
Minnesota
R3 Racing Offline
R3 Racing  Offline
Minnesota
You must not know Mark. When that thing is done and in the car, it will look a piece of jewelry. Mark invented the word "anal".
Re: "The Block" - Such a pretty sight........... [Re: R3 Racing] #2541978
08/27/18 12:25 PM
08/27/18 12:25 PM
I didn't mean the owner, he said BES built it and I've seen many other engine builders do this.
Just adds a lot of time masking off and prepping for paint.
CHIP
Re: "The Block" - Such a pretty sight........... [Re: an8sec70cuda] #2542048
08/27/18 03:23 PM
08/27/18 03:23 PM
I paint all my motors after they are assembled and ready to go (lots of cleaning solvent and brake cleaning solvents used to remove any oil or grease) and before dyno testing them up
What's a little time and effort masking them worth shruggy
Re: "The Block" - Such a pretty sight........... [Re: markz528] #2542056
08/27/18 03:34 PM
08/27/18 03:34 PM
I paint the shortblock before all the pretty stuff gets bolted on. Sorry for the post hi-jack markz528, I'm sure that's gonna be a good runnin engine! Glad to see someone who actually has their hands on one of these blocks.
CHIP
Re: "The Block" - Such a pretty sight........... [Re: fast68plymouth] #2542226
08/27/18 11:10 PM
08/27/18 11:10 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Y'all don't like my primer color????? whistling
It's gonna be orange. Am I crazy for wanting to paint the heads? Might start a separate thread for that question. BES asked if I wanted it painted - nope. If it leaks I want to fix the leaks before it gets painted. I can tape with the best of them.......
I hope to use my headers but if they won't work with the dyno they have headers. My headers are Hooker 2 inch 5209's - same as I run in the race car.
They basically port matched the intake - but they got opened up quite a bit. No additional work was done to the intake.
Thanks Ron - Monte Smith used to call me anal also...........
Re: "The Block" - Such a pretty sight........... [Re: MR_P_BODY] #2542228
08/27/18 11:11 PM
08/27/18 11:11 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
wave
K&N Bought a long time ago............
Re: "The Block" - Such a pretty sight........... [Re: markz528] #2542230
08/27/18 11:13 PM
08/27/18 11:13 PM
So. Burlington, Vt.
So. Burlington, Vt.
5209’s have worked on the dyno for me....... they will likely be able to use them.
Re: "The Block" - Such a pretty sight........... [Re: markz528] #2543670
08/31/18 01:10 AM
08/31/18 01:10 AM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Hits the dyno on Wednesday......... boogie
Re: "The Block" - Such a pretty sight........... [Re: markz528] #2543674
08/31/18 01:25 AM
08/31/18 01:25 AM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
Nice looking build you have there. Please be sure to post updates as you get through the dyno and into the car.
I wish I knew Monte well enough to have had him call me anal ... RIP buddy
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
