What will it run?
#2541583
08/26/18 03:07 PM
08/26/18 03:07 PM
Posts: 23 TN
RRandP92
TN
69 dart 3225lbs race weight,caltracs,520ci,trick flow 270, .650 lift 265ish duration solid roller, 11.5:1 compression,indy intake,1050 dominator,727,8in converter specd by ultimate, 3.70 rear gear,325/50 radial. Let's here it. Hopefully get to make some test hits Friday.
Re: What will it run?
[Re: RRandP92]
#2541593
08/26/18 03:30 PM
08/26/18 03:30 PM
Posts: 570 UK
rb446
UK
I'll take a guess at your fwhp to be 690, if your chassis is up to it and its all running on song your ticket could look something like this with the tyre height@28"?+3.7's>
60 Foot E.T. : 1.35 1/8 Mile E.T. : 6.15 1/8 Mile Trap Speed : 110.61 1/4 Mile E.T. : 9.74 1/4 Mile Trap Speed : 138 1/4 Mile Trap RPM : 6,114+slip
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: RRandP92]
#2541709
08/26/18 08:01 PM
08/26/18 08:01 PM
Posts: 43,200 Bend,OR USA
Cab_Burge
if the weight is with the driver it should run 9.80 at 137.+ MPH once sorted out with open headers My old pump gas Duster ran 9.993 at 134.8 MPH corked up(3.0 inch exhaust system to the rear bumper) on pump swill with a 518 C.I. 400 block stroker motor with a little less compression weighing 3450 lbs. with me in it. IHTHs Good luck, let us know what it does
[Re: RRandP92]
#2541762
08/26/18 10:34 PM
08/26/18 10:34 PM
Posts: 23 TN
RRandP92
TN
Weight is with driver. 2in fenderwell headers into 3.5in exhaust straight through mufflers dumped in front of rear tires. Would be great if it went a 10.0 N/A
[Re: RRandP92]
#2541768
08/26/18 10:44 PM
08/26/18 10:44 PM
Posts: 25 Santa Rosa, Calif
angleiron2
Santa Rosa, Calif
I have a similar 512 combination. My 69 Dart is 3500 pounds with Driver. Indy EZ heads opened to max wedge size ,Indy intake ,1050 , one of Dwayne’s solid rollers 268/270 duration 646/646 lift,11.2 to1 compression,Ultimate 9 1/2 converter. The car has Caltracs and 410 Ratio with 10.5 x 29.5x 15 radials. Yesterday it ran 9.86 trough the mufflers at 134.I think it would probably do 9.70 uncorked with a little tweaking, but its time to slow it down a bit.
[Re: RRandP92]
#2541777
08/26/18 11:04 PM
08/26/18 11:04 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Yesterday it ran 9.86 trough the mufflers at 134. Nice going Dave!!😎 Did you get scolded? As for the OP, should be easy low low 10’s. 9’s in decent air after it’s sorted out.
[Re: angleiron2]
#2541781
08/26/18 11:13 PM
08/26/18 11:13 PM
Posts: 13,189 aZLiViN
J_BODY
aZLiViN
I have a similar 512 combination. My 69 Dart is 3500 pounds with Driver. Indy EZ heads opened to max wedge size ,Indy intake ,1050 , one of Dwayne’s solid rollers 268/270 duration 646/646 lift,11.2 to1 compression,Ultimate 9 1/2 converter. The car has Caltracs and 410 Ratio with 10.5 x 29.5x 15 radials. Yesterday it ran 9.86 trough the mufflers at 134.I think it would probably do 9.70 uncorked with a little tweaking, but its time to slow it down a bit. Judgng from your location were you at Famoso? Or Sears Point (Infineon.. whatever they’re calling it these days).
[Re: RRandP92]
#2541796
08/26/18 11:25 PM
08/26/18 11:25 PM
Posts: 570 UK
rb446
UK
Weight is with driver. 2in fenderwell headers into 3.5in exhaust straight through mufflers dumped in front of rear tires. Would be great if it went a 10.0 N/A high 9.80's..should do it easy with good hook/60..... As a comparison which is not even close, my mates '69 Dart, 3180, 446ci/12.7/eddy 320cfm heads/.590 purple solid/victor int/950 DP/4.56/13x31's/SS springs/5000 stall, trap@6700, 10.1's@132+..599fwhp
[Re: J_BODY]
#2541800
08/26/18 11:33 PM
08/26/18 11:33 PM
angleiron2
Santa Rosa, Calif
I have a similar 512 combination. My 69 Dart is 3500 pounds with Driver. Indy EZ heads opened to max wedge size ,Indy intake ,1050 , one of Dwayne’s solid rollers 268/270 duration 646/646 lift,11.2 to1 compression,Ultimate 9 1/2 converter. The car has Caltracs and 410 Ratio with 10.5 x 29.5x 15 radials. Yesterday it ran 9.86 trough the mufflers at 134.I think it would probably do 9.70 uncorked with a little tweaking, but its time to slow it down a bit. Judgng from your location were you at Famoso? Or Sears Point (Infineon.. whatever they’re calling it these days). I was at Sears Point/ Sonoma Raceway. Beautiful day, nice sunny 70 degree day.
