383 plug wire brackets, 68 vs. 69
#2541570
08/26/18 02:18 PM
08/26/18 02:18 PM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
I am looking to clean up the plug wires on my '68 383 which is currently using factory exhaust manifolds. I am missing most of the OE plug wire brackets. I plan to make my own wires but want to use OE brackets to keep them neat and properly routed.
Looking around, I noticed the brackets are slightly different between 68-69. 69 looks a little neater to me? Not sure exactly why though, just a vague notion.
Is there any reason I couldn't use the 69 brackets on a 68?
Thanks for any input.
- Greg
'71 Duster '72 Challenger '17 Ram 1500
Re: 383 plug wire brackets, 68 vs. 69
[Re: RMCHRGR]
#2541610
08/26/18 04:05 PM
08/26/18 04:05 PM
RMCHRGR
Spahn Ranch
I figured they would be almost identical but wanted to make sure there were no hidden pitfalls like a different accessory layout or some superseded part.
Stinks that the brackets only accommodate 7MM wires, kind of ruins my entire plan. Are there any factory BB wire brackets that will accommodate 8MM wires?
[Re: RMCHRGR]
#2541760
08/26/18 10:33 PM
08/26/18 10:33 PM
Posts: 356 Greenwood Lake, NY
fuelishnsilly
Greenwood Lake, NY
Why not try and file out the holes to fit the 8MM wires? You can always redip them in the rubber coating.
inherited a 69 roadrunner from my grand pop.
[Re: fuelishnsilly]
#2541788
08/26/18 11:17 PM
08/26/18 11:17 PM
RMCHRGR
Spahn Ranch
Why not try and file out the holes to fit the 8MM wires? You can always redip them in the rubber coating. Guess I could do that. Plasti-Dip, correct? I hate buying stuff then modifying it but realistically, it may be the only choice if I stay with the exhaust manifolds.
[Re: A12]
#2541835
08/27/18 12:55 AM
08/27/18 12:55 AM
RMCHRGR
Spahn Ranch
Do you have the correct '68 right/passenger's side valve cover with the plug wire brackets attached? Yes.
[Re: RMCHRGR]
#2542370
08/28/18 10:49 AM
08/28/18 10:49 AM
RMCHRGR
Spahn Ranch
So I ordered a set of '69 wire brackets with the plastic inserts. Like said above, I'm going to file out the plastic retainers to fit the 8mm wires, seems reasonable enough. Also ordered a tub of Plasti-Dip to re-finish the coated brackets after I hog them out. Not going for a 'factory correct' appearance here but I like to use the factory pieces where I can, just seems to make life easier when trying to fit things. Thanks for the info.
