Re: water pump housing plug ?
[Re: marcjames]
#2541566
08/26/18 02:11 PM
08/26/18 02:11 PM
RapidRobert
heat it with your torch then wick in some candle wax
[Re: Supercuda]
#2541567
08/26/18 02:12 PM
08/26/18 02:12 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I find heat works wonders on such things. Propane is usually not enough. If you don't nave an oxy/acetylene set up, take the housing to a friend that does, or a local shop. They should be able to remove that plug in minutes.
I have mechanical Aptitude. I can screw up anything.
[Re: marcjames]
#2541602
08/26/18 03:40 PM
08/26/18 03:40 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
Another vote for heat and wax.Also Ive had them where I can heat them and cold water while its hot.Seems the water can make steam and wick into the threads.Rocky
Chrysler Firepower
