Page 1 of 4 1 2 3 4
Indy aluminum blocks #2541515
08/26/18 12:00 PM
08/26/18 12:00 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
How much power you all pushing through these blocks?
Re: Indy aluminum blocks [Re: racerx] #2541520
08/26/18 12:10 PM
08/26/18 12:10 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I'm building a 605 with an Indy block now. Planning on 1,000 hp N/A. The blocks can handle way much more than that.
[image][/image]
Re: Indy aluminum blocks [Re: racerx] #2541521
08/26/18 12:10 PM
08/26/18 12:10 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Indy says the water blocks are good to 1500. I think Bob,the guy with the Procharged 69 Dart broke an early one but he was at 1800+ hp on alcohol.
Re: Indy aluminum blocks [Re: sgcuda] #2541540
08/26/18 01:00 PM
08/26/18 01:00 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Really didn't what to do a aluminum block but there aren't a lot of choices there, but curios what type of power people were putting though them. Thought I read that Indy were going to start producing cast iron blocks in the next couple years hope there some truth to this shruggy
Re: Indy aluminum blocks [Re: fbs63] #2541542
08/26/18 01:08 PM
08/26/18 01:08 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
That's a lot I know of a ford fellow racer that runs a dart block with a turbo that run 1500 hp but he has concreted the block O-ring the heads/block , thought that was a bit much but.
Re: Indy aluminum blocks [Re: racerx] #2541543
08/26/18 01:10 PM
08/26/18 01:10 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
[quote=racerx]Really didn't what to do a aluminum block but there aren't a lot of choices there, but curios what type of power people were putting though them. Thought I read that Indy were going to start producing cast iron blocks in the next couple years hope there some truth to this shruggy [/quote
First off unless your class requires it why in heck whould you pick cast iron over aluminum. That’s like picking lead over helium
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Indy aluminum blocks [Re: pittsburghracer] #2541670
08/26/18 06:46 PM
08/26/18 06:46 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
It's not a class car , round here it's a run what you brung type thing and I prefer to do a cast type block over aluminum . You have a KB block you willing to part with it? work
Re: Indy aluminum blocks [Re: racerx] #2541706
08/26/18 07:56 PM
08/26/18 07:56 PM
Cab_Burge Online work
Cab_Burge  Online Work
I know a well funded west coast Ford SB heads up 10.5 outlaw racer that went faster with a Dart cast iron filled block than they did with a filled Fontana aluminum block on NOS and with both super chargers and turbos work
The rings sealed up way better and held the vacuum a lot better with the iron block than it did with the aluminum block towing it every where except for the burn out and the run work
They where able to keep the weight the same as well as the weight on the front and back tires up
Test, test and test some more, if you want to go faster than every one else in your class wrench shruggy
Re: Indy aluminum blocks [Re: racerx] #2541710
08/26/18 08:03 PM
08/26/18 08:03 PM
PA.
"Little"John
"Little"John
PA.
Aaaaaaaaa NO. 😂
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Indy aluminum blocks [Re: pittsburghracer] #2541712
08/26/18 08:06 PM
08/26/18 08:06 PM
I see that Brodix is offering cast iron Chevy and Ford blocks for drag racing now work shruggy
Re: Indy aluminum blocks [Re: racerx] #2541855
08/27/18 02:21 AM
08/27/18 02:21 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I'm running an Indy block.
Just a home built car. Runs 4.80's at 150+ in the 1/8. Indy -1 heads
Re: Indy aluminum blocks [Re: FastmOp] #2541878
08/27/18 07:34 AM
08/27/18 07:34 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Is this with a power adder or NA ?If so how was ring seal?
Re: Indy aluminum blocks [Re: racerx] #2541883
08/27/18 08:13 AM
08/27/18 08:13 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Single turbo. Seals fine at 7500
Re: Indy aluminum blocks [Re: FastmOp] #2541994
08/27/18 01:15 PM
08/27/18 01:15 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Not sure where you might have read it but I highly doubt Indy will be making IRON blocks anytime soon if ever. He made them years ago and his quote to me was. Making iron blocks is the easy part, making MONEY with them is almost impossible. Todd
Re: Indy aluminum blocks [Re: racerx] #2542469
08/28/18 01:39 PM
08/28/18 01:39 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Casting Iron blocks is the easy part. Getting someone to machine them is a whole other issue. They are hard on equipment and that's where the costs lie after the core boxes are done.
Re: Indy aluminum blocks [Re: racerx] #2542578
08/28/18 04:12 PM
08/28/18 04:12 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
How far off are we from getting Keith Black blocks off the shelf? I e-mailed a couple of there suppliers about a low deck block but never heard back...would it not be the best block for a say a 1500hp build currently?
A new iron curtain drawn across the 49th parallel
Re: Indy aluminum blocks [Re: racerx] #2542622
08/28/18 05:43 PM
08/28/18 05:43 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
More KBs are about 12 to 15 weeks out.The lowdeck will not be available for the future although that could change with PROVEN demand. It is true that several lowdecks were made for some of the back ordered pieces, but these were a total nightmare,and insane to produce from a cost standpoint.
I have the first wedge that I have done from soup to nuts ready to put some fire in the hole in the next day or so. I will say SO far I have been pretty happy with the way it went together. NOt a total fire breather but motor should make around 880 to 900. We shall see and I will let you guys know what I find.
Todd
Re: Indy aluminum blocks [Re: sasquatch] #2542680
08/28/18 07:31 PM
08/28/18 07:31 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Todd
that would be good to see/hear Todd
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Indy aluminum blocks [Re: sasquatch] #2542689
08/28/18 07:47 PM
08/28/18 07:47 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
Todd
Thanks for the info... post the RB build if you don’t mind.
Re: Indy aluminum blocks [Re: racerx] #2542716
08/28/18 08:22 PM
08/28/18 08:22 PM
Texas
Chief Offline
Chief  Offline
Texas
1300 HP, 1050 tq @ 6800. Blown injected on Alky. 6th year on it no issues.
Dave Covey
Page 1 of 4 1 2 3 4
