Re: Single to a dual reservoir master cylinder
[Re: mopar4ya]
#2541438
08/26/18 12:27 AM
08/26/18 12:27 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I would use a later dual drum M/C, like from a 68 Fury. It will bolt in place of you existing M/C.
What are "HD brakes"? that is unclear.
Do you mean power brakes?
You will need to mimic the all 68 drum setup for the M/C connections.
Front port connects to the rear drums. Rear port will T to the front brakes.
[Re: 64Bel]
#2541457
08/26/18 02:26 AM
08/26/18 02:26 AM
RapidRobert
there's a guy on FABO that has a new alum MC/4 to 2 conversion plate for sale for reasonable money. Not sure what bore it is. I'm about tempted to nab it myself.
[Re: Supercuda]
#2541478
08/26/18 09:29 AM
08/26/18 09:29 AM
Posts: 2,655 western PA
mopar4ya
western PA
The car has the 11 inch rear brakes. I am going have to verify if it has power brakes, I don't believe it does. If it is a manual brake car I assume it will require a brake pedal rod to match the master cylinder? The car is at a local shop and they called me to help them find a master cylinder. I've never done one but I knew it has been discussed here a lot and I would get pointed in the right direction. Thanks!
[Re: mopar4ya]
#2541485
08/26/18 09:59 AM
08/26/18 09:59 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
We run 70 C body masters.Juist have to make sure it for drum/drum.Disc /drum is different inside.manual brakes the rod still works with it.Just have to make sure the small retainer is on the rod so it dosent back out.I did run a small 68 type master at first.then changed to the 70 c body one.Used the same in my kids 62 300 also.they bolt right up.later alumimum masters require and adapter etc to use.Will need to run new lines for master also.been a long time since Ive done a drum only car. Rocky
Chrysler Firepower
[Re: mopar4ya]
#2541493
08/26/18 10:55 AM
08/26/18 10:55 AM
Supercuda
About to go away
About to go away
up yours
In an all drum set up there is no proportioning valve. There is a safety valve, which is available from Doctor Diff. http://www.doctordiff.com/brake-valve.htmlIf it's manual brakes you need to swap the rod over. You will need a new retainer. Might ask Doc if he has any retainers separate, I know you can get them with his adjustable pushrod kit.
[Re: mopar4ya]
#2541506
08/26/18 11:40 AM
08/26/18 11:40 AM
therocks
Niles , Ohio
Last 2 masters I bought had the retainers IIRC small vacuum hose also works.Rocky
Chrysler Firepower
[Re: cudaman1969]
#2541770
08/26/18 10:55 PM
08/26/18 10:55 PM
RapidRobert
stick a drill bit into the brass cones & you'll feel the springiness if it has a RPV. that way if it doesn't then you wont have to pull the cone if it would need to come out of there which as you know it does for discs. EDIT It is easy to damage the brass cone when removeing it so if you dont have to then your ahead.
[Re: mopar4ya]
#2542273
08/28/18 12:38 AM
08/28/18 12:38 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
When I took the single pot off my 63 Belvedere I used a 66/77 manual master.I just put a strange aluminum one on.You can heve the old one if you want
[Re: SportF]
#2542416
08/28/18 12:09 PM
08/28/18 12:09 PM
Posts: 8,275 fredericksburg,va
cudaman1969
fredericksburg,va
I see a lot of people changing to dual master without putting in a "safety valve/proportioning valve/shuttle valve". Without that valve controlling the output of the master, you don't have a dual system. Very true, glad you brought it up, the most important part that makes the system work.
[Re: SportF]
#2542482
08/28/18 01:58 PM
08/28/18 01:58 PM
Supercuda
About to go away
About to go away
up yours
I see a lot of people changing to dual master without putting in a "safety valve/proportioning valve/shuttle valve". Without that valve controlling the output of the master, you don't have a dual system. Welcome to the show, it was already brought up and sources linked.
[Re: SportF]
#2542844
08/29/18 01:14 AM
08/29/18 01:14 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I see a lot of people changing to dual master without putting in a "safety valve/proportioning valve/shuttle valve". Without that valve controlling the output of the master, you don't have a dual system. That makes sense but on my 63 the only valve I can add is the safety valve as mine is power drum brakes. It uses no metering valve and a prop valve would only need be in the rear line. And it has no safety valve from the factory being a single drum brake unit. I don't need the safety valve feature as of course I would know if I loose half the brakes by the pedal. My brakes work good as I have it and if I have a prop valve in my rear line the only function the safety valve would do in my setup is turn on a lite on the dash if I wired it in to warn of a fluid loss in one side. I can see on disc/drum of course but don't see it really needed on my setup that I can think of. Ron
