THERMAL WRAP #2541372
08/25/18 09:07 PM
08/25/18 09:07 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
I need to shield some SS lines off the MC. Wrap them tight or create a sleeve and allow an air space?
Re: THERMAL WRAP [Re: A/MP] #2541402
08/25/18 10:17 PM
08/25/18 10:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
How far away is your heat source and what is
the source
wave
Re: THERMAL WRAP [Re: A/MP] #2541407
08/25/18 10:28 PM
08/25/18 10:28 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I'm leaning towards air space, with a very thin reflective shield type material, SS is pretty good at resisting heat transfer if you go with a metal. twocents
Re: THERMAL WRAP [Re: A/MP] #2541416
08/25/18 11:03 PM
08/25/18 11:03 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Header. Varies from 3/4" to 1 1/2".
Re: THERMAL WRAP [Re: A/MP] #2541419
08/25/18 11:20 PM
08/25/18 11:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I used a header rap, tight to control the temp
on my trans lines(they are about a 1/4" away
from my headers).. I rapped both the headers
and the trans lines
wave
Re: THERMAL WRAP [Re: A/MP] #2541524
08/26/18 12:19 PM
08/26/18 12:19 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
We made an aluminum shield (on a Duster) never had a problem with heat again. Either way I would leave air space (tube type). Contact means heat transfer to me.
Re: THERMAL WRAP [Re: A/MP] #2541538
08/26/18 12:56 PM
08/26/18 12:56 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Thought that air would act as an insulator. Thermal coated headers and the wrap kills the coating, so i'm stuck with shielding each individual brake line. Fenderwell headers bring the pipes close to the brake lines and MC. Have a shield for the MC.
Re: THERMAL WRAP [Re: A/MP] #2541625
08/26/18 04:41 PM
08/26/18 04:41 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Fire sleeve works great for that.
Re: THERMAL WRAP [Re: A/MP] #2542269
08/28/18 12:31 AM
08/28/18 12:31 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
you can wrap it tight with header wrap, soak it with high temp paint to keep it from unraveling and use stainless safety wire to secure the ends. Works real good for insulating the headers but they don't last as long before cracking. Stainless will only go so long before cracking compared to a real good metal like Inconel...Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
