Page 3 of 3 1 2 3
Re: when to replace torsion bars [Re: mopar dave] #2536512
08/15/18 12:01 AM
08/15/18 12:01 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
FWIW, OE sizes are 0.83, 0.85, 0.87 and 0.89 and have paint daubs in yellow, olive (green), blue and white, respectively. There's not a huge difference in stiffness between them. By far the most common are the 0.85" bars, which should work fine at the dragstrip. I saw a mention of a reconditioning service on the Firm Feel web site a while back. I don't know if that includes an annealing, resetting and heat treating. If they're damaged they're no good for their intended purpose.
twocents
Re: when to replace torsion bars [Re: mopar dave] #2537166
08/16/18 01:57 PM
08/16/18 01:57 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
There is a pair of the .870 340 bars used in the classifieds for $40. Still have paint no rust. Temping as i wanted brand new, but that price sure looks good to me.
Re: when to replace torsion bars [Re: mopar dave] #2537179
08/16/18 02:24 PM
08/16/18 02:24 PM
AndyF Online content
AndyF  Online Content
Buy them and try them. New ones are more than $300 so at $40 you can't really go wrong. If they aren't quite right for your car you can always put them back up for sale. Someone with a small block car might need them.
Re: when to replace torsion bars [Re: mopar dave] #2537188
08/16/18 02:39 PM
08/16/18 02:39 PM
Washington
madscientist Offline
Washington
40 bucks and a bit of shipping sounds like a good deal. I'd give that a whirl. You ain't out much if you don't like it and it gives you a starting point that isn't your old used bars.
Re: when to replace torsion bars [Re: AndyF] #2537222
08/16/18 03:38 PM
08/16/18 03:38 PM
Mt Morris Michigan
Mt Morris Michigan
Think i will Andy. Been thinking about it all morning. Ill give him a call.
Re: when to replace torsion bars [Re: mopar dave] #2537367
08/16/18 08:47 PM
08/16/18 08:47 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
If you don't i might have to.
Re: when to replace torsion bars [Re: JAMESDART] #2537378
08/16/18 09:02 PM
08/16/18 09:02 PM
Mt Morris Michigan
Mt Morris Michigan
I just bought them. $40 for the bars and $40 to ship, so $80. Better than $325+shipping
Re: when to replace torsion bars [Re: mopar dave] #2540352
08/23/18 11:04 AM
08/23/18 11:04 AM
Mt Morris Michigan
Mt Morris Michigan
I received the $40 TB today. I bought the removal tool as well. Any tips on getting these installed? The old ones i had out once when i rebuilt the entire front suspension, but that was 1997. Probably start on this next week sometime. Thanks
Re: when to replace torsion bars [Re: mopar dave] #2540381
08/23/18 11:59 AM
08/23/18 11:59 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
pull clips from the rear of TB socket
pull the upper control arm bump stops off
unbolt lower shock mount
loosen the TB adjusters completely
back the lower control arm nut off most of the way
use a prybar to push the LCA towards the rear, do this by the pivot pin
the bar will slide back and you should be able to pull it out by hand, you can slide the bar all the way back through the TB crossmember
remember the bars are side specific
let the LCA hang all the way down and push the adjuster blade all the way down, then slide the bars in
reassemble, just snug the pivot pin bolt in the air, final torque when it's at ride height...
Re: when to replace torsion bars [Re: krautrock] #2540401
08/23/18 12:47 PM
08/23/18 12:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your better off getting a set of used A-body bars..
they have already taken a set and wont drop
for quite some time.. any new bar that hasnt
been pre loaded will take a set
wave
Re: when to replace torsion bars [Re: mopar dave] #2540412
08/23/18 01:20 PM
08/23/18 01:20 PM
Anoka County, MN
Leigh Online content
Leigh  Online Content
Anoka County, MN
After the adjuster bolt and nut is out, pry down on the adjusting arm, this will relieve the tension, and it will slip right out.
Re: when to replace torsion bars [Re: Leigh] #2540569
08/23/18 07:13 PM
08/23/18 07:13 PM
Mt Morris Michigan
Mt Morris Michigan
Ok. Thanks guys. That info is appreciated. Mike, these are used 340 A body bars. 892/893. They are marked left and right. Would the driver side be the left?
Re: when to replace torsion bars [Re: mopar dave] #2540596
08/23/18 08:08 PM
08/23/18 08:08 PM
Washington
Washington
Yes, drivers side is left.
Re: when to replace torsion bars [Re: mopar dave] #2540616
08/23/18 09:27 PM
08/23/18 09:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When looking at odd and even parts just think of you in the
drivers seat
wave
Re: when to replace torsion bars [Re: MR_P_BODY] #2541722
08/26/18 08:18 PM
08/26/18 08:18 PM
Mt Morris Michigan
Mt Morris Michigan
Gonna get started on this soon and looking at the bars, they have a slight twist. How do i identify the front and rear of the bars? Does it make any difference?
Re: when to replace torsion bars [Re: krautrock] #2541813
08/27/18 12:05 AM
08/27/18 12:05 AM
iagree hammer up
Re: when to replace torsion bars [Re: Cab_Burge] #2542051
08/27/18 03:25 PM
08/27/18 03:25 PM
Mt Morris Michigan
Mt Morris Michigan
Yeah, thanks cab. Followed those directions except left the shocks bolted up and the pivot pin nut tight. Slid right out no problem. 2hr job. Its about time a project went straight forward without a ton of issues cropping up along the way. Thanks guys.
Page 3 of 3 1 2 3
