Re: Can H beam rods be rebuilt? [Re: Digger73] #2540346
08/23/18 10:58 AM
08/23/18 10:58 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Save yourself some grief and buy new ones IMHO.
http://www.molnartechnologies.com/rods-domestic.html
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Can H beam rods be rebuilt? [Re: Eric] #2540385
08/23/18 12:04 PM
08/23/18 12:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mine were new H-beam rods but I changed the balance
on the crank so I had to tweak the rod balance and
the small end.. they had been on the dyno for 10
minutes
wave
Re: Can H beam rods be rebuilt? [Re: Digger73] #2540516
08/23/18 05:04 PM
08/23/18 05:04 PM
Portland, Oregon
Digger73 Offline OP
Digger73  Offline OP
Portland, Oregon
Thanks everyone for the advise and information.
The flip side of this is that the crank will also need some attention.
So, by the time I buy new rods, engine bearings, crank work and re balance.
I am most of the way to a new 440 source stroker kit. If I go the new kit route I can opt for more compression and more stroke. Just looking for the best option at this time.
Thanks all,
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
Re: Can H beam rods be rebuilt? [Re: sgcuda] #2540529
08/23/18 05:50 PM
08/23/18 05:50 PM
an8sec70cuda Offline
Originally Posted By sgcuda
If the rod discolored, I would replace it.
iagree
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Can H beam rods be rebuilt? [Re: Digger73] #2540557
08/23/18 06:42 PM
08/23/18 06:42 PM
Portland, Oregon
Digger73 Offline OP
Digger73  Offline OP
Portland, Oregon
When I get home tonight I will get some pictures down loaded of the rods and the bearings.
Digger73 (Mike)
Re: Can H beam rods be rebuilt? [Re: Digger73] #2540650
08/23/18 11:12 PM
08/23/18 11:12 PM
Portland, Oregon
Digger73 Offline OP
Digger73  Offline OP
Portland, Oregon
Here are the pictures of what my rods look like now.
Digger73 (Mike)
Re: Can H beam rods be rebuilt? [Re: Digger73] #2540663
08/23/18 11:40 PM
08/23/18 11:40 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Heck that didn’t get very hot from those pictures. I would torque it together and check it with a set of mics or a bore gauge.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Can H beam rods be rebuilt? [Re: Digger73] #2540674
08/23/18 11:58 PM
08/23/18 11:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont like that one rod.. has blue about a
quarter of the rod width.. make sure you check
that rod out closely
wave
Re: Can H beam rods be rebuilt? [Re: Digger73] #2540771
08/24/18 08:55 AM
08/24/18 08:55 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Definitely, the start of something bad. But, it looks like you caught it pretty early. You should have it checked for stretch. Those rods can be resized on the big end, but I don't know if the heat that caused the blue streak is significant enough to warrant replacement. Check with your machinist. 1 rod isn't a significant expense to save the motor.
More importantly, I think I would be having the crank magnafluxed at this point.
Re: Can H beam rods be rebuilt? [Re: sgcuda] #2540987
08/24/18 06:18 PM
08/24/18 06:18 PM
dogdays Offline
dogdays  Offline
IN GENERAL: Any steel connecting rod will have a heat treatment at some point. As these are 4340 rods I am 100% sure that they, like any 4340 rod, will have been heat treated in a very specific way. When one gets out of the straight carbon steels and into the stronger alloys the heat treat can increase strength maybe 30%. Also each designer will have his own targets for strength and ductility.
Here are temps to achieve different colors. This is by uniform heating and then rapid cooling. This is different from the colors that happen when the steel is heated and held at a specific temp, like "cherry red heat".
1.HEAT COLOURING OF IRON AND STEEL
yellow/228C
brown/254C
purple red/265C
light blue/264C
dark blue/293C
Here is a normal heat treat for 4340:PROCESSING TEMPERATURES
Typical
Forge
2200°F MAX
Normalize
1550/1650°F
Case Harden
1475/1550°F
Anneal
1475/1575°F
Temper
1200°F & 400°F
I started out thinking use them. But, 400F is around 200C so even the least colored rods have been heated past the last tempering temperature. For any kind of high performance work I'd sell them as-is on Ebay and buy new ones.
R.
