frontend height on 68 coronet rt #2540264
08/22/18 11:41 PM
08/22/18 11:41 PM
kentucky usa
K
kentuckydodge Offline OP
K
kentucky usa
can anyone tell me on a 68 coronet rt , how high the front should be from the ground and where I should measure from ?
Re: frontend height on 68 coronet rt [Re: kentuckydodge] #2540278
08/23/18 12:56 AM
08/23/18 12:56 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
It's the difference of two measurements under the suspension. You can down load a service manual for free on mymopar.com. Maybe somebody could post the pictures of where to measure.
Re: frontend height on 68 coronet rt [Re: kentuckydodge] #2540572
08/23/18 06:25 PM
08/23/18 06:25 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
There's pictures in the service manual. twocents
Re: frontend height on 68 coronet rt [Re: kentuckydodge] #2540728
08/24/18 02:18 AM
08/24/18 02:18 AM
You can set the ride height where you want it (so the front wheels/tires look "good" in the wheelwells) within reason especially needed with aftermarket rims/tires. As you know loosen the front nuts on the (2) tapered studs before cranking the bolts & bounce/jounce the front end to let it settle for a final check to get the height where you want it. Alot of shops set the RH too low going by their "book" specs.
Re: frontend height on 68 coronet rt [Re: RapidRobert] #2541397
08/25/18 09:07 PM
08/25/18 09:07 PM
kentucky usa
K
K
kentucky usa
ok thanks for the help
