Page 3 of 5 1 2 3 4 5
Re: My new heads are killing me need help [Re: fast68plymouth] #2539977
08/22/18 12:34 PM
08/22/18 12:34 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
How much for the before and after dyno jobs.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: My new heads are killing me need help [Re: 70dusterjohn] #2539981
08/22/18 12:47 PM
08/22/18 12:47 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Depends on what it is(how involved the installation is), but the least you’d pay nowadays here is $550 per session.
Keep in mind, most of the time when it comes to this, the owner as already spent a pile of money and numerous wasted trips to the track trying to get the cars performance to improve.
The system they’ve been using to make decisions on how or what to try next hasn’t been working for them....... so they’re looking for a different approach.
It’s no different than someone bringing you some ported heads and asking if you can make them any better.
You’d flow them before you started working on them, right?
Re: My new heads are killing me need help [Re: fast68plymouth] #2539986
08/22/18 01:07 PM
08/22/18 01:07 PM
PA.
"Little"John
"Little"John
PA.
Absolutely but I didn’t charge for flowbench testing unless it was someone walking in off the street. Then it was 50.00 but then again maybe this is why I totally gave up doing work for others. Lol
I kinda figured 400-500 for a dyno session
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: My new heads are killing me need help [Re: 70dusterjohn] #2539994
08/22/18 01:29 PM
08/22/18 01:29 PM
So. Burlington, Vt.
So. Burlington, Vt.
A lot of the time when a cars performance is off, the first thing that gets blamed is the motor for not making enough power.
It’s usually when it’s not a “known good” combo, and/or has never been on the dyno.
In that situation you don’t really know what it “should” run.
If you have a bunch of 700hp parts, and your motor makes 700hp...... you’re doing okay.
One thing to keep in mind is, many combos don’t have another “easy” or cost effective 50hp in them.
The pre-disassembly dyno test can save them a bunch of money if the motor combo is already nearly maxed out.
Going from that 700hp to 750hp might require new heads, more cubes, a better block, etc.
Sometimes that next 25-50hp is way beyond what their budget is....... and what money they can spend would often be better spent on other areas, if the car isn’t running numbers that equate to what the motor is making for power.
In a situation like where the OP is at now, dyno testing the motor is part of the diagnostic process.
Just like when your “check engine” light in the dash comes on.
You can hook the scan tool up to it............. or start swapping out parts hoping the light will go out.
Re: My new heads are killing me need help [Re: Dodgem] #2540002
08/22/18 01:44 PM
08/22/18 01:44 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted By Dodgem
Id put the jets back to last year. then check Cam degree!
Checking that the cam is installed properly is easy and can be done in the car. I had one where everything was installed correctly but was way off from where it should have been.
'63 Dodge 330
11.19 @ 121 mph
Re: My new heads are killing me need help [Re: 70dusterjohn] #2540093
08/22/18 05:06 PM
08/22/18 05:06 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
Why have you not made a full pass?
Re: My new heads are killing me need help [Re: 70dusterjohn] #2540116
08/22/18 06:18 PM
08/22/18 06:18 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
is that a vague way of asking if his throttle cable is working properly?
Re: My new heads are killing me need help [Re: 70dusterjohn] #2540171
08/22/18 08:55 PM
08/22/18 08:55 PM
Deerfield, Ohio
70dusterjohn Offline OP
Deerfield, Ohio
Could my msd box going bad cause bad performance. I think it just took a crap on me today ..
Re: My new heads are killing me need help [Re: 70dusterjohn] #2540178
08/22/18 09:05 PM
08/22/18 09:05 PM
Washington
madscientist Offline
Washington
Sure can. It will throw you a curve ball for sure. Most people think the ignition either works or it doesn't. I've found that isn't correct. Even with a mag.
Re: My new heads are killing me need help [Re: 70dusterjohn] #2540185
08/22/18 09:22 PM
08/22/18 09:22 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Hopefully that's all it is, then you can get it all back together and make some passes.
Re: My new heads are killing me need help [Re: 70dusterjohn] #2540189
08/22/18 09:32 PM
08/22/18 09:32 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Well I just pulled the motor for the 4th time this season and I can tell you it’s getting old pulling a B.B. out of an a-body. I noticed that the exhaust looks all sooted up. I think I have my carb space on backwards so not sure what that will do. Then I got busted tell on my converter and can’t seem to find anyone to fix it so I Guess I will weld them up and try it all again. I don’t know what else to do ???
John have you tried Quickdraw converters? Lots of guys use them. I can also hook you up with a friend that works at Perfect converter company, several fast local guys use them. The guy lives around the block from me(Bubba).1-440-232-9677
Re: My new heads are killing me need help [Re: ProSport] #2540198
08/22/18 09:56 PM
08/22/18 09:56 PM
tboomer Online work
tboomer  Online Work
I was going to ask how the battery and charging system are....
Re: My new heads are killing me need help [Re: 70dusterjohn] #2540200
08/22/18 09:59 PM
08/22/18 09:59 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Read my post way earlier in this thread
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: My new heads are killing me need help [Re: 70dusterjohn] #2540216
08/22/18 10:38 PM
08/22/18 10:38 PM
So. Burlington, Vt.
So. Burlington, Vt.
I suppose....... but, you said:
Checked wiring
Checked timing
Checked comp test 170-175
Checked leak down was not a noticeable difference
Checked cap and rotor
Checked crank trigger
Checked ignition box/ tried my 7al
Re: My new heads are killing me need help [Re: 70dusterjohn] #2540219
08/22/18 10:50 PM
08/22/18 10:50 PM
Deerfield, Ohio
Deerfield, Ohio
Yeah that was my bad . I never took it to that track with the 7 hit just started it and ran it up the road. The 6 was fine and now all the sudden I ha e nothing
Re: My new heads are killing me need help [Re: ProSport] #2540230
08/22/18 11:36 PM
08/22/18 11:36 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I have a perfect 9"converter behind the HEMI - looks good and works great - I asked for 5400 stahl and exactly what I got - price was really good also
Re: My new heads are killing me need help [Re: 70dusterjohn] #2540369
08/23/18 11:39 AM
08/23/18 11:39 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
That's good to hear DoubleD, Bubba is a good guy I'll be getting my next converter from Perfect.
Re: My new heads are killing me need help [Re: 70dusterjohn] #2540574
08/23/18 07:27 PM
08/23/18 07:27 PM
Deerfield, Ohio
Deerfield, Ohio
Pulled another msd 6 al out of my street car and now it won’t start and I did the test like msd says and it works . So I checked the old box and got the same . Now the car won’t even fire .. I’m pulling my hair out with this car this year ...🤔🤔
Re: My new heads are killing me need help [Re: 70dusterjohn] #2540583
08/23/18 07:41 PM
08/23/18 07:41 PM
So. Burlington, Vt.
So. Burlington, Vt.
I seem to be having trouble keeping up with what’s going on......
The right way to test the box is with an MSD ignition tester.
Re: My new heads are killing me need help [Re: 70dusterjohn] #2540585
08/23/18 07:43 PM
08/23/18 07:43 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
Prob. the dist pick up .
If it's MSD I had one go out on mine .
