Re: Radiator fan type question
[Re: 1970RT]
#2538983
08/20/18 12:57 PM
08/20/18 12:57 PM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
I can tell you the MP clutch fan package has about most "loose" oe clutch the folks who set the part up could find. (6 cylinder B van, if I remember correctly?) It's not set up for max cooling, but for the least power loss of the parts they had on hand back then. I personally like the 5 blade fan that came with that kit but the main reason is because it's noticeably less noisy than the 7 blade fans, not because the cooling is amazingly great. I've currently teamed it up with a tighter rv spec clutch from the parts store 'cause I am spinning everything slower with an underdrive pulley. Don't do what I did and use an underdrive crank pulley and life will be easier.
The fan clutch slips to reduce power loss....a fixed fan will draw more power from the engine but will give you more cooling at lower vehicle speeds.
Rich H.
Esse Quam Videri
[Re: 1970RT]
#2539095
08/20/18 03:45 PM
08/20/18 03:45 PM
Posts: 4,206 New York
polyspheric
New York
a long highway drive doesn't need a fan at all. If it runs hot over 40 mph it's a water problem.
Boffin Emeritus
[Re: polyspheric]
#2539184
08/20/18 06:17 PM
08/20/18 06:17 PM
Posts: 2,860 Pattison Texas
CSK
Pattison Texas
a long highway drive doesn't need a fan at all. If it runs hot over 40 mph it's a water problem. That wont work down here in Southeast Tx LOL, I run a 7 blade direct Flex a lite blade, it keeps my car 180ish all day long traffic or moving, air temps over 100 deg, 512cid with COLD AC .
[Re: 1970RT]
#2539219
08/20/18 07:52 PM
08/20/18 07:52 PM
polyspheric
New York
Above 35 the air flow through the core from vehicle speed is much stronger than the fan provides.
Boffin Emeritus
[Re: polyspheric]
#2539244
08/20/18 08:28 PM
08/20/18 08:28 PM
CSK
Pattison Texas
Above 35 the air flow through the core from vehicle speed is much stronger than the fan provides. My quote,,,That wont work down here in Southeast Tx LOL, I run a 7 blade direct Flex a lite blade, it keeps my car 180ish all day long traffic or moving, air temps over 100 deg, 512cid with COLD AC . I am not going to argue, I know it for a FACT.
[Re: wyrmrider]
#2539643
08/21/18 04:09 PM
08/21/18 04:09 PM
Posts: 43,176 Bend,OR USA
Cab_Burge
[Re: 1970RT]
#2539787
08/21/18 10:29 PM
08/21/18 10:29 PM
Posts: 30 CA
wyrmrider
CA
14 miles In the summertime when there is a wreck it's like forever much worse than the Grapevine or the road from the 10 to 29 palms I did not mention the load that working the torque converter puts on a radiator- shift down if stooped put it in neutral and rev it up a little I've seen new stock rebuilt 440 motorhime motors burn up never gets hot in Eastern Oregon does it another test we did was on transmission coolers note that the factory later went to 3/8 line and 1/2 inch on the diesels one poster figured out the flow difference but I recommend 1/2 inch line and a 100 plate and fin cooler with 1/2 in and out the two together can cut the pressure at the trans return point by 45 lbs that's a lot less restriction you should be able to fill a quart jar in 20 seconds idling in N (or P with the Transgo Pat valve)
[Re: 1970RT]
#2539808
08/21/18 11:10 PM
08/21/18 11:10 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
CSK I agree.I run an 18 inch stainless flex fan on my 65.Been on for over 20 years and works flawless.ran a flex on my Jeep plow vehicle.Daily driver to the tune of over 100K and no problems.In fact the jeep ran a bit cold.The 65 built 440 runs 180 all day all the time.Only fan I ever saw broke was the stocker one on my 65 years ago.Rocky
Chrysler Firepower
[Re: 1970RT]
#2540126
08/22/18 06:38 PM
08/22/18 06:38 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I now run a 16 inch Spal 2 speed fan only as a pusher.9:1 534 inch 2nd gen blown Hemi.No shrouds and no problem.Runs at 170* or up to 185* on a 95* day sitting in traffic.
