Turn signal cam/harness question... #253885
03/14/09 10:27 PM
03/14/09 10:27 PM
Colorado Springs
T/A CARe Offline OP
T/A CARe  Offline OP
Colorado Springs
I bought a replacement harness for the turn signal and the part number match up gives me a harness with a wider 4 way flasher that DOESN'T fit in the column slot. (See pics. The smaller knob is the original). Anybody have a solution to the correct switch and harness?
Thanks!
Re: Turn signal cam/harness question... [Re: T/A CARe] #253886
03/15/09 12:01 AM
03/15/09 12:01 AM
New State
kidmopar Offline
kidmopar  Offline
New State
I believe you have a 1970 ONLY switch and the replacement is a 1971 - up switch . One says "Hazzard" the new one says "FLASHER" ? I think you need part # 2947905 switch that is NOT reproduced ?
