87 New Yorker Rear Door Locks #2538836
08/20/18 03:27 AM
08/20/18 03:27 AM
Keizer, Oregon U.S.A.
E
elmor353 Offline OP
elmor353  Offline OP
E
I can't get the rear door locks to work. They won't lock with the electric lock switch and you can not manually push them either. The front door locks work just fine. I'm wondering if a child proof lock mechanism might be causing this? Any ideas?
Re: 87 New Yorker Rear Door Locks [Re: elmor353] #2538867
08/20/18 07:56 AM
08/20/18 07:56 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Maybe both motors are a bit rusted inside. I had a pass door on a ramcharger do that, had to take motor apart, clean rust out and re-lube. All was well.
Re: 87 New Yorker Rear Door Locks [Re: buildanother] #2539161
08/20/18 05:44 PM
08/20/18 05:44 PM
E
elmor353 Offline OP
elmor353  Offline OP
E
Shouldn't you be able to manually push the lock buttons, even if the motors are rusted? I guess I'll just have to pull the door panels and look.
Re: 87 New Yorker Rear Door Locks [Re: elmor353] #2539206
08/20/18 06:55 PM
08/20/18 06:55 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If the motors and the linkage are bad its almost impossible to manually lock them Had the same problem with elect locks on my Ramcharger.Got some new solonoids from the junkyard.pretty much the same for a lot of year with rear wheel drive.Rocky
Chrysler Firepower
Re: 87 New Yorker Rear Door Locks [Re: elmor353] #2540360
08/23/18 11:16 AM
08/23/18 11:16 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The motors are hooked directly to the lock mechanism so if they are stuck so is the lock. You would have to try disconnecting them to see if it frees up the locks.
Re: 87 New Yorker Rear Door Locks [Re: elmor353] #2540367
08/23/18 11:31 AM
08/23/18 11:31 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If you disconnect the solonoids IIRC the locks will work.Did it on mt Ram as I got tired of them sticking.Rocky
Chrysler Firepower
Re: 87 New Yorker Rear Door Locks [Re: therocks] #2540747
08/24/18 04:53 AM
08/24/18 04:53 AM
E
elmor353 Offline OP
elmor353  Offline OP
E
Thanks guys. That helps a lot and makes sense. If it doesn't rain here tomorrow, I'll pull the door panels and check it out.
