Re: Flywheel conversion challenge
[Re: PR-Chapin]
#2538777
08/20/18 12:23 AM
08/20/18 12:23 AM
RapidRobert
Welcome here! I'm wondering if your shop could duplicate the balance of the 360 wheel over to the 318 one (I'm a 904 guy) & I did work on a 318 outboard speedboat once & it was a strange reverse rotation beast (that threw us for awhile).
[Re: PR-Chapin]
#2538782
08/20/18 12:34 AM
08/20/18 12:34 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
the pattern is to locate where to remove metal to balance to 360 specs. It isn't flywheel specific, it is only engine specific.
[Re: Supercuda]
#2538786
08/20/18 12:42 AM
08/20/18 12:42 AM
RapidRobert
How's your math! A balancer told me that trigonometry is needed to find the locations with the pic Supercuda posted. He also said that you can use smaller drill bits, that you're just wanting to remove the same amt of material but then there was the drill point angle difference so I just took it in & let them do it.
[Re: RapidRobert]
#2538817
08/20/18 01:53 AM
08/20/18 01:53 AM
Posts: 954 garnett kansas
rhad
garnett kansas
doesnt someone make a offset plate that bolts between the crank and standard flywheel that provides the correct imbalance to make the 360 balance correctly????
my ladder of success is missing some rungs
[Re: elmor353]
#2538842
08/20/18 04:11 AM
08/20/18 04:11 AM
Posts: 10 Ontario
PR-Chapin
Ontario
Thanks. If the balance plate works, that would be the quickest fix (and cheapest!).
[Re: RapidRobert]
#2538843
08/20/18 04:17 AM
08/20/18 04:17 AM
Posts: 10 Ontario
PR-Chapin
Ontario
As far as I know this is a right hand rotation motor. Guess I should check the engine tag to be sure! Left hand rotation are more rare, usually found tandem with right hand rotation motor in twin inboard engine boats. Edit: My 360 is from an inboard/outboard and the prop rotation can be changed in Volvo/Chrysler outdrives so I'm pretty sure my engine is right hand rotation same as vehicles.
[Re: PR-Chapin]
#2538845
08/20/18 04:28 AM
08/20/18 04:28 AM
Posts: 10 Ontario
PR-Chapin
Ontario
How do I know if this marine engine has a cast crank or forged crank? Does it make a difference for balancing the flywheel?
[Re: PR-Chapin]
#2538938
08/20/18 11:40 AM
08/20/18 11:40 AM
Supercuda
About to go away
About to go away
up yours
All 318's are internally balanced, cast or forged, so no difference in balancing the flywheel.
All 360's are cast, so no difference in balancing the flywheel.
[Re: elmor353]
#2538940
08/20/18 11:42 AM
08/20/18 11:42 AM
Supercuda
About to go away
About to go away
up yours
Quick Time RM531 balance plate. I used one on my 360 with a 318 flywheel and it balanced just fine. Bolts between the crankshaft and flywheel. They are about $30.00 from Summit. This does not work out of the box. It needs to be balanced with the rotating assembly.
[Re: PR-Chapin]
#2539090
08/20/18 03:32 PM
08/20/18 03:32 PM
Supercuda
About to go away
About to go away
up yours
Supercuda: I am curious why the adaptor plate would need to be balanced with the rotating assembly. Because it is not balanced for any engine. Look at the application listing for it. Every Mopar engine that needs external balance is listed. There are are least four different imbalances I can think of that this plate claims to handle. 360 all 19.79 in-oz 340 cast crank 4.22 in-oz 400 all (includes 440 and 383 cast crank)12.9 in-oz 440 with heavy rods 6.5 in-oz all have different imbalance weight requirements. What this plate does is take the place of the flywheel or torque converter as far as balancing goes. You bolt this thing to the rotation assembly and use it to neutral balance the assembly. then you can use any neutral balance torque converter or flywheel.
[Re: Supercuda]
#2539104
08/20/18 03:51 PM
08/20/18 03:51 PM
Posts: 10 Ontario
PR-Chapin
Ontario
I'm a bit confused. You say: "You bolt this thing to the rotation assembly and use it to neutral balance the assembly. then you can use any neutral balance torque converter or flywheel." That seems to be exactly what I want. I need something that will balance the 360's engine ("rotation assembly") to eliminate vibration if its externally balanced factory flywheel is changed to zero balanced 318 flywheel. But you're saying the counterweight of this plate is not specific to what's needed for 360?
Edit: I see. The QuickTime product applications menu indicates the adaptor plate is not specific to 360 but applies to multiple V-8 engines Chrysler made from 1975-78 including, curiously, the 318 which I thought were all internally balanced.
So I'm better off having a machinist drill the 318 flywheel per the blueprint above? Or can the machinist tune the adaptor to meet the specifications you list? Guess I better cancel that order.
[Re: PR-Chapin]
#2539143
08/20/18 05:10 PM
08/20/18 05:10 PM
Posts: 10,775 North Dakota
6PakBee
North Dakota
Why wouldn't drilling the 318 flywheel to the 360 drawing work? If you start with something that is neutral balance it shouldn't matter what the diameter is. All you are looking for is a certain amount of unbalance and the drawing gives you that.
[Re: PR-Chapin]
#2539145
08/20/18 05:12 PM
08/20/18 05:12 PM
Supercuda
About to go away
About to go away
up yours
that balance plate is designed with more imbalance than needed so your machinist can trim it to balance the rotating assembly as applicable to your specific setup. As it, it's not a bolt on. Not sure how to make it more clear.
The 318 is internally balanced, which make you wonder what Quick Time is thinking, or not thinking. there are no instructions and frankly the website is poorly, very poorly, written.
What your machinist can do is best asked of the machinist. But it should not be an issue for them to use the given prints and drill to match. No trig needed.
[Re: elmor353]
#2539170
08/20/18 05:54 PM
08/20/18 05:54 PM
Supercuda
About to go away
About to go away
up yours
It stands to reason since the 360 takes the most amount to balance, then you would only have to trim it for the engines that use less weight to balance them. I installed mine as is, to my crank and then bolted on my 318 flywheel. No vibrations whatsoever. And that is why I work on my own stuff. Then I know it's done right.
