Re: My new heads are killing me need help
[Re: fast68plymouth]
#2539977
08/22/18 12:34 PM
08/22/18 12:34 PM
Posts: 20,164 PA.
pittsburghracer
"Little"John
"Little"John
PA.
How much for the before and after dyno jobs.
[Re: 70dusterjohn]
#2539981
08/22/18 12:47 PM
08/22/18 12:47 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Depends on what it is(how involved the installation is), but the least you’d pay nowadays here is $550 per session.
Keep in mind, most of the time when it comes to this, the owner as already spent a pile of money and numerous wasted trips to the track trying to get the cars performance to improve. The system they’ve been using to make decisions on how or what to try next hasn’t been working for them....... so they’re looking for a different approach.
It’s no different than someone bringing you some ported heads and asking if you can make them any better. You’d flow them before you started working on them, right?
#2539986
08/22/18 01:07 PM
08/22/18 01:07 PM
Posts: 20,164 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Absolutely but I didn’t charge for flowbench testing unless it was someone walking in off the street. Then it was 50.00 but then again maybe this is why I totally gave up doing work for others. Lol I kinda figured 400-500 for a dyno session
[Re: 70dusterjohn]
#2539994
08/22/18 01:29 PM
08/22/18 01:29 PM
fast68plymouth
So. Burlington, Vt.
A lot of the time when a cars performance is off, the first thing that gets blamed is the motor for not making enough power. It’s usually when it’s not a “known good” combo, and/or has never been on the dyno. In that situation you don’t really know what it “should” run. If you have a bunch of 700hp parts, and your motor makes 700hp...... you’re doing okay.
One thing to keep in mind is, many combos don’t have another “easy” or cost effective 50hp in them. The pre-disassembly dyno test can save them a bunch of money if the motor combo is already nearly maxed out. Going from that 700hp to 750hp might require new heads, more cubes, a better block, etc.
Sometimes that next 25-50hp is way beyond what their budget is....... and what money they can spend would often be better spent on other areas, if the car isn’t running numbers that equate to what the motor is making for power.
In a situation like where the OP is at now, dyno testing the motor is part of the diagnostic process. Just like when your “check engine” light in the dash comes on. You can hook the scan tool up to it............. or start swapping out parts hoping the light will go out.
[Re: Dodgem]
#2540002
08/22/18 01:44 PM
08/22/18 01:44 PM
Posts: 4,669 Wichita
GY3
Wichita
Id put the jets back to last year. then check Cam degree! Checking that the cam is installed properly is easy and can be done in the car. I had one where everything was installed correctly but was way off from where it should have been.
[Re: 70dusterjohn]
#2540178
08/22/18 09:05 PM
08/22/18 09:05 PM
Posts: 4,457 Washington
madscientist
Washington
Could my msd box going bad cause bad performance. I think it just took a crap on me today .. Sure can. It will throw you a curve ball for sure. Most people think the ignition either works or it doesn't. I've found that isn't correct. Even with a mag.
[Re: 70dusterjohn]
#2540185
08/22/18 09:22 PM
08/22/18 09:22 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Could my msd box going bad cause bad performance. I think it just took a crap on me today .. Hopefully that's all it is, then you can get it all back together and make some passes.
[Re: 70dusterjohn]
#2540189
08/22/18 09:32 PM
08/22/18 09:32 PM
ProSport
Akron, Ohio
Well I just pulled the motor for the 4th time this season and I can tell you it’s getting old pulling a B.B. out of an a-body. I noticed that the exhaust looks all sooted up. I think I have my carb space on backwards so not sure what that will do. Then I got busted tell on my converter and can’t seem to find anyone to fix it so I Guess I will weld them up and try it all again. I don’t know what else to do ??? John have you tried Quickdraw converters? Lots of guys use them. I can also hook you up with a friend that works at Perfect converter company, several fast local guys use them. The guy lives around the block from me(Bubba).1-440-232-9677
[Re: 70dusterjohn]
#2540200
08/22/18 09:59 PM
08/22/18 09:59 PM
Posts: 11,710 Portage,michigan
B3422W5
Portage,michigan
Could my msd box going bad cause bad performance. I think it just took a crap on me today .. Read my post way earlier in this thread
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: 70dusterjohn]
#2540216
08/22/18 10:38 PM
08/22/18 10:38 PM
fast68plymouth
So. Burlington, Vt.
Could my msd box going bad cause bad performance. I think it just took a crap on me today .. I suppose....... but, you said: Checked wiring Checked timing Checked comp test 170-175 Checked leak down was not a noticeable difference Checked cap and rotor Checked crank trigger Checked ignition box/ tried my 7al
[Re: ProSport]
#2540230
08/22/18 11:36 PM
08/22/18 11:36 PM
Posts: 2,296 NE Ohio
DoubleD
NE Ohio
Well I just pulled the motor for the 4th time this season and I can tell you it’s getting old pulling a B.B. out of an a-body. I noticed that the exhaust looks all sooted up. I think I have my carb space on backwards so not sure what that will do. Then I got busted tell on my converter and can’t seem to find anyone to fix it so I Guess I will weld them up and try it all again. I don’t know what else to do ??? John have you tried Quickdraw converters? Lots of guys use them. I can also hook you up with a friend that works at Perfect converter company, several fast local guys use them. The guy lives around the block from me(Bubba).1-440-232-9677 I have a perfect 9"converter behind the HEMI - looks good and works great - I asked for 5400 stahl and exactly what I got - price was really good also
[Re: 70dusterjohn]
#2540369
08/23/18 11:39 AM
08/23/18 11:39 AM
ProSport
Akron, Ohio
That's good to hear DoubleD, Bubba is a good guy I'll be getting my next converter from Perfect.
[Re: 70dusterjohn]
#2540583
08/23/18 07:41 PM
08/23/18 07:41 PM
fast68plymouth
So. Burlington, Vt.
I seem to be having trouble keeping up with what’s going on...... You’re trying to get it to fire........ but you said: I just pulled the motor for the 4th time The right way to test the box is with an MSD ignition tester.
